Storing numbers in speed dail for the Savin Fax 3699
Can you explain how to store fax phone numbers in the speed feature on the Savin Fax 3699. The manual has been lost.
    Scholar:
  • 159 Answers
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Posted on Aug 19, 2008
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
How do i fax?
First you enter phone line in to the fax machine and then feed the fax paper on the top side of the fax machine then dail the number on the dail pad after the beep press the start button your fax start work.Fax throughput and office productivity are enhanced by scanning faxes into memory while the machine is busy. You can return to work, confident that their faxes will be transmitted as soon as the line is free.
Nov 25, 2009 | Brother IntelliFax-2480C Fax
How to program a number into the one-touch dialing buttons
Press the dataregistration key.dataregistration will apear on the screen press the arrow down untill Tellregistration will be displayed.Press set or ok or start.! Toutch speed dails will be displayed.Press set or ok or start.It will show the available one touvh numer.Enter and insert name and fax of the sender.
Sep 10, 2009 | Canon LaserClass 2060P Plain Paper Fax
Need to change 1 fax number in group dialing on a cfx-L4000 fax
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
Nov 19, 2008 | Canon Laser Class 310 Fax
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
164 people viewed this question
jasbo
jasbo
