Question about AEG B5741-4 Electric Single Oven
Pyrolytic cleaning fault
When i select pyro cleaning the oven starts but after several mins it stops and f5 flashes on the display.the oven has not cleaned any ideas please
  • vicky-webste Mar 28, 2009
    I have the same problem but mine flashes F1
Fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Posted on Aug 20, 2008
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
My zanussi zpb 1260 oven has stopped working after a pyrolytic clean. I set the oven and the display is correct but after a couple of seconds the the temp goes to 20 and nothing happens, tried switchi
Go to Zanussi . com select UK then manuals you will need more information a serial number and then download it, there should be an answer in there okay.
Regards
John
Nov 02, 2014 | Zanussi Ovens
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
Self cleaning F5
Sorry you haven't had an answer to your inquiry yet. You may not even require a remedy any longer, but in the event you do I'll post it.
The "F5" in the smw272 wall unit is indicating the on-board watchdog has detected a oven temperature sensor fault/failure. The remedy issued by Thermador's tech support and authorized technicians service manual's is to first replace the oven temperature sensor. If the display should still display after wards, replace the main relay board.
It may be too late to suggest, but you may be best served having an authorized thermador tech look at it.
Hope that helps, better late than never hopefully.
macmarkus :)
Sep 27, 2009 | Thermador SMW272 Electric Double Oven
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
AEG B5741-4 Electric Single Oven Logo
656 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
