Question about Crown CE1000 2-Channel Amplifier
CE1000 Our amp seems to go in and out on one side. Wiggle the wire and it can come on.
  • 4,234 Answers
You have bad connections at the inputs. If you can solder, carefuilly remove the board that has the input connector and resolder the jack onto the PC board. This should be done ASAP as with the connection loose like that the circuit board traces are soon to break.
Posted on Aug 18, 2008
The fan on my CE1000 does not come on when the amp is powered up. The amp seems to be playing normally, but I am afraid I may over heat the amp if the fan is not working. Is this normal?
The Thermal Senser on the Heat sink may be Defective. Heat the Thermal senser and see if Fan Turns on. It is a device with 2 screws holding it to the heat sink
Oct 07, 2010 | Crown CE1000 2-Channel Amplifier
Crown CE1000 and CE2000 both clipping with low signals
for some reason channel one of one of our amps started clipping. i first noticed it with the drum kit but it slowly moved to the vocals as well. i haven't noticed this issue before today. what do i need to adjust to keep it from clipping?
Jun 04, 2010 | Crown CE2000 2-Channel Amplifier
Fan running
Yes, many of the pro sound amps throttle the fan based on an internal temperature sensing device.
May 14, 2010 | Crown CE1000 2-Channel Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
Fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Mar 26, 2010 | Crown CE1000 2-Channel Amplifier
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
I need to send my CE1000 crown amp in for repair.  Where can I send it?
Typing "amp repair" in google should get you a fairly comprehensive list.
I fixed a couple of my amps recently which had blown transistors. These were pretty obvious to spot (look for scorch marks on the PCB) and only a couple of £s to replace - significantly cheaper than a professional repair job, it just depends weather you have the courage to do it yourself!
Jan 24, 2009 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
Oct 20, 2007 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
137 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
