Question about Lexmark Office Equipment & Supplies
On my lexmark x3470 it says that my cover is open and as far as I can tell it is closed.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
That can be from a problem with control software. try reinstalling fresh set of drivers first.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Incorrect "Cover open" indication
Hi, the cover sensor may have gotten stuck. So, even though the cover is closed, it's still sensing that it's open. Here's a link on what you can do to remedy the problem. http://bit.ly/9UYvzL . Hope this helps
Mar 10, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Open cover problem
You have go to service, becouse the switch for cover is brouken, and they need put them ih close mode. In same primter model switch is in diferent placeses
Sep 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Printer will not print or shut down
reset memory; unplug; plug back in while HOLDING DOWN STOP KEY. This resets/clears memory
tape down the little black plastic lever (usually on left side) so it can't pop back up which causes it to invoke error message "cover open" and "cover closed" who needs a machine to tell a cover is open?
Mar 31, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Sep 29, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
X3470
my printer keeps saying cover opened and won't swcith off or nothing can u please help me
Jul 03, 2008 | Lexmark X3470 All-In-One InkJet Printer
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
