Car Audio & Video Logo
Anonymous Posted on Jun 06, 2011
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i cliped...i forgot which slot i cliped them from. anyone have a ford contour that would be willing to take out there stereo and look at the order of their wires for me? my colors are 1.yellow/red 2.white 3.yellow/green 4.orange/black 5.blue 6.black/green 7.black/green
  • Anonymous Jun 06, 2011
    i already found that and the colors dont match mine
Anonymous
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Jun 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
12796
Points
130
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakershaving trouble wiring in my - ir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakers
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Who knows the wiring color codes or where to get free diagram for a 2010 Ford Fusion SE Factory radio to hook up aftermarket pioneer stereo?
https://www.modifiedlife.com/2010-ford-fusion-radio-wiring-diagram/ ----------match up harnesses and splice together
How do I bypass a factory amp in a 2014 dodge charger se? I am having trouble hooking up my 5 channel amp which leads me to believe that there maybe a factory amp installed on my car.
Doubtful, trace wires from speakers using test light, does new amp have coaxial connectors? you may have incompatible model, probably need to match amp with new head unit, worst case you can rewire speakers directly to amp, use new wires, leave old wires in place just cut ends and put tape over.
1helpful
Color codes for stereo
They make kits just for this. Just plugs into the existing harness and then you run you wires to the wires from that harness, some may even have matching plugs that go directly to the Head units wire harness plug. I did My Mustang by cutting into the wire Harness and simply used a multimeter to check for battery, memory 12 volts and running light or dash board Illumination wires then you can test the wires coming out from the stock radio to see which are right, left , front, rear, antenna out, etc..
I just labeled them with magic marker on some masking tape with what they were before I cut off the harness permanently.
I have a 2001 ford focus se and the previous owner had a stereo just taped together with the wires from the car . The wires are just sticking out and i bought a new one and i need to know what the colors...
a reputable car stereo place will sell you a wiring harness for your vehicle and after market stereo, that tells you which color wires to hook to what.
To hook upa cd player after they have cut the factory plugs! there r 2 different ones. one clip has eight speaker wires abd the other clip has six wires! what wires do i hook togater to make it work?
your stereo should have come with a wiring diagram for it that at least tells you what color wire is what coming out of the stereo just match up the colors/signals per this chart: This for for a typical ford- http://www.installdr.com/Harnesses/Ford-Wiring.pdf
I bought i new stereo and i am having troubles hooking it up cause the wiring for the car is weird and we dont know how to hook it up
first of all if there is a radio shack near you or walmart you can go and get what is call installation kit and it will have a diagram showing you how to install the radio and to hook the right wires.
1helpful
2answers
Positive battery cable
i think that one goes to the starter. how bout cutting off the end and putting an after market cable end?
2answers
Radio wiring diagram 1996 ford contour
Go to auto wreckers lots in cars out their
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
