Question about Garmin StreetPilot C330 GPS Receiver
Internal Battery is dead
While on a road tripscreen displayed Battery Dead
  • vaughn440 Aug 18, 2008
    According to Manuel that came with Unit they adv not to attempt removal ofd battery
  • 19,396 Answers
Here is a movie on how to replace Garmin's battery
Internal Battery is dead - 2.jpg YouTube - Replacing the Battery in Your Garmin
Posted on Aug 18, 2008
  • 594 Answers
If your StreetPilot c3xx is showing low battery, the unit is no longer receiving external power. Please proceed with the following steps:
  1. Check the fuse in the vehicle power cable.
  2. Check the connections between the unit and the vehicle.
  3. Make sure the vehicle is supplying power to the cigarette lighter (check the fuse for the cigarette lighter, turn on vehicle's ignition, try using another accessory in the cigarette lighter).
  4. Try remounting the unit into the cradle.
Also try remounting the unit into the cradle:
  1. Place the front bottom part of the screen into the cradle.
  2. Roll the unit backwards until it snaps into place.
  3. Place your thumb on the bottom of the mount below the screen of the unit.
  4. Place the rest of your fingers on the top of the unit.
  5. Squeeze the unit and the cradle together to make sure it is seated correctly.
If your c3xx is still not receiving external power in the vehicle, please connect the unit to a computer with the supplied USB cable to verify that the unit will still charge. If the unit is able to charge on the computer, the vehicle mount may need to be replaced. If the unit will not charge on the computer, the unit may need to be repaired. Please contact Garmin Product Support for repair or additional support.
    Genius:
  • 3,422 Answers
HI,
If your garmin won't turn on the please reset it.
    Brigadier General:
  • 3,614 Answers
How old is your unit now?
  • micromaster
    micromaster Aug 18, 2008
    check the battery & wire connections, or better replace the battery
No display, no response with fresh batteries inserted properly. Basically seems dead. Timer has been inside for months, so it is dry.
Sharon, sounds like a internal fault, try one more thing, sharply rap it on a counter top to see if it will display. If displays, this would mean battery contacts are bad,loose wire, or cracked solder joint internal, if not probably should consider it defective and replace.
Apr 03, 2016 | Hardware & Accessories
Saturn L300 battery drain 2002
Vehicles have a varied number of electronic control modules for the engine , ABS , air bags , body control , anti- theft , keyless entry etc.. When the vehicle is parked ,key off these modules are suppose to enter into sleep mode. Some times they don't go to sleep , bad module ,wiring problem or a light is staying on. How to Find Parasitic Battery Drain
Dec 26, 2014 | 2002 Saturn L-Series
Car was turned off as well as air condition, however air continued to stay on eventhough air gauge displayed that the air unit should have been off.I disconnected battery cable and the air went off but...
The battery won't go dead while you're driving the car.
It's utterly impossible for anything to operate with the battery cables disconnected.
There's probably an internal short in the solid state resistor that controls the blower motor.
May 09, 2011 | Pontiac Bonneville Cars & Trucks
It goes dead going down the road then wont start and baTTERY GOES DEAD
I would charge the battery up and check it. Also check if the alternator is charging the battery whle it is running.
Apr 20, 2011 | 1988 Volkswagen Cabriolet
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
My internal backup battery is dead, can anyone tell me where to find the specs to replace the internal battery? and what type of internal battery is it? Thanks
If it's been a few months since you have used the camera it's normal to be dead.
Charge the camera and use it and the clock battery should come to life.
The camera will work fine even if the battery does not work, however, you will not be able to record time and date.
Al
Feb 16, 2011 | Sony DCR-PC350E Mini DV Digital Camcorder
When i on the camera ,then display time& date setup.i setup the time & det,and quit.next time same eagain.
the internal memory battery is dead it is used to store all internal memory have it replaced
Dec 07, 2010 | Sony CCD-TRV228E Camcorder
Charging system failure
Hello. This means for some reason your alternator is not functioning properly. The engine will start and run until your battery goes dead. If you have a voltmeter display on your dashboard the needle will be below 12 to confirm that the alternator is not functioning properly. You need to have this checked out before your battery goes dead so you don't end up stranded on the road. I hope this helps, good luck.
Feb 03, 2010 | 2005 Buick LaCrosse
Stereo problem with hyundai sonata 2000 after dead battery
After verifying all the connections to the radio are good (power and ground, antenna, speakers, etc), the audio unit has an internal malfunction. Solution: Replace the audio unit.
Mar 21, 2009 | 2000 Hyundai Sonata
Garmin StreetPilot C330 GPS Receiver Logo
125 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
