Question about ASUS K8S-MX Motherboard
Formating HD Hi i Have a ASUS K8S-MX mother board and i am using a SATA HD. i am trying to format my Hard Drive i have done this before but have lost the SATA RAID bootup disk...i have tried to make a new floppy by copying from the cdrom provided but it is not working i have tried all Raid files. i restart the pc with xp in the cd drive, ask to boot from cd. go into the setup and press F6 comes up to press s to load third party riad contoler . message then comes up advising that TXTsSETUP.OEM can not be found...now i have this TXT SETUP file on the floppy but it does not work...i have tried dwnloading the zip file from the net...but i still have the same problem...please help.
  • Anonymous Aug 24, 2008
    hello
    dont worry about this... u just use another XP cd to boot and install os.
    some CD may lost some important datas written in the same.
    Just use XP Professional..
    otherwise u make a call to 09865512192
  • 781 Answers
Download " Hirens Boot CD " it has a lot of partitioning tools on it try one to check and set hard drive into partitions
Posted on Aug 21, 2008
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Dec 07, 2009 | ASUS K8S-MX Motherboard
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
To download Asus k8s-mx motherboard driver
Hi aneeshkem,
All the driver's for the Asus K8S-MX motherboard are listed at this link.
http://support.asus.com/download/download.aspx?modelname=K8S-MX&SLanguage=en-us
Enjoy!
Mike
Jul 31, 2008 | ASUS K8V-MX Motherboard
Jeeva1
hi jeeva,
to format ur hard disk simple way installed ur window xp/vista from installing the operating system it will be easier to format ur hard disk
steps1;
1) just put bootable windowsin ur cdrom
2) run the set up
3) follow the procedures while installing from there u can format ur hard disk
regards
shailesh
Mar 10, 2008 | ASUS K8S-MX Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
ASUS K8S-MX Motherboard Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
