Hdd not detected
Xp does not recognise my seagate db35.3 series 250 gigabyte hdd. The seagate site says it is used for video editing. Does it need different formatting or ata cable?
Thaurfen the wiz advised me to use device manager to scan for hardware changes, and it worked. I would like to thank him and give him a star rating but I cannot find his posting now. Sorry about that.
Posted on Aug 19, 2008
MY SEAGATE hdd 500 NOT DETECTED BY MY MY BIOS
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Jun 29, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
My computer XP does not recognise seagate db35.3 series 250 gigabyte hdd
make sure disk is correct commected and spins at starting.
Aug 18, 2008 | Televison & Video
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
I'm on Indonesia, exactly on Central Java... My HDD is Seagate FreeAgent 250 GB... I've plugged the USB cable and i connected the HDD to my PC... then, the led is just blinking for once, then black out,...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Aug 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hello. I recently installed Windows 7 64bit Ultimate edition. I was initally unable to access my seagate external HDD. I tried to take ownership and played around with the permission settings to no avail...
It may be the USB chipset on the motherboard that needs a new 64bit driver downlod. I used Driver Detective to update my Intell chipset when I upgraded to 7 now all my external drives show up. Try using other USB ports on your computer first to force the computer to reload the driver for the new port.
Nov 09, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cant load xp onto sata HDD
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Jul 12, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
