Question about Minolta Office Equipment & Supplies
Minolta copier Di3510 error code cobao - Minolta Office Equipment & Supplies
  • 4726888 Oct 20, 2008
    I have the same error code, but it is on a Imagistics im2020 copier
  • Minolta Master
  • 6,005 Answers
Output tray elevation motor is bad or there something stopping it from lowering or raising.
Posted on Dec 28, 2014
3 Suggested Answers
  • 18 Answers
SOURCE: I have a Minolta Copier/Printer
C13D2: Magenta IU EEPROM access error. try reinstalling the Mag Imaging
Unit connector might not making a good contact check for bent pins ect...make sure too reboot copier.
Posted on Nov 27, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: My minolta dialta copier has
This code deals with the AIDC or Automatic Image Density Control failure. Most always this code is caused by toner collecting on top of the sensor. If you happen to know how to remove the Imaging Unit and then the Drum from the Imaging Unit then you could clean the sensor yourself. If not then I would recommend you call a service technician to correct the problem.
Basically what is happening is there is a thin mylar seal called the anti-spill mylar which is suppose to keep the toner off of the sensor. But these start to fail over time and allow toner to drop down onto the sensor which results in false readings and the C0F24 code. The mylar must either be replaced or what I do as a field fix is to reform the mylar back to it's like new shape so it seals. Then clean the sensor area of toner then re-install the drum and imaging unit back into the machine.
Good Luck and Thank You for using Fixya.
Posted on Aug 04, 2010
Bizhub 2510earer coad cobao
The FN finisher unit elevator motor malfunction.Remove the finisher unit and work with out.
Jul 22, 2014 | Konica Minolta Clutch for Di3510 3010 2510...
How to fix a cobao error on a DI3510f multifunction printer
COBAO - Elevator motor ascent/descent drive failure.Remove the finisher unit and work without.
Jul 08, 2014 | Minolta Di3510f Bizhub Copier
How to add konica minolta bizhub Di3510 on windows xp
Down load the driver from konicaminolta or use the disk with the copier.
Jan 22, 2014 | Minolta Di3510 All-In-One Laser Printer
Minolta code cobao
Check the stapler in side the machine.
Jan 13, 2014 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta dialta di3510
The pass code for the admin mode on the di3510 should be 00000000 (8 zerros ) OR Elevation drive motor failure for the finisher /service manual
Aug 28, 2012 | Minolta Di3010 Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
COBAO error on NEC IT3520/KM Dialta 2010
Sir,
Was there a trash can or box of paper underneath the finisher part that moves up down. the code is failure of the up and down motor for the finisher. Normal happens when the trays that move down they hit something. or the mootr has failed. Open/close the door to the finisher, power off both power switches including the one on the rear left side and the one on the front panel. wait ten seconds then turn them on again. Also check to make sure there is not something binding the tray system
Jul 02, 2009 | Konica Minolta DiALTA Di200 Copier
Konica di3510 there is a code on the screen cobao
May 05, 2009 | Konica Minolta DiALTA Di200 Copier
Bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Jan 20, 2009 | Office Equipment & Supplies
193 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
