HELLO' hi glad ... i have problem my tv ,what is the common problem,standby only.CT-20S10M2panasonic tnxz...jb
  • ea246 Aug 18, 2008
    STANDBY PROBLEM,CT-20PANASONIC TV
  • 40 Answers
Could be the malfunction of the remote control.push `P+`on the front panel of yourTV.if no change means :this is a malfunction of the power switch block or flyback block.please contact the nearest repair shop.
Posted on Aug 19, 2008
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
I have a cello e1906dvb 19
good news and glad you fixed it--welcome to the world of TV repair.
Apr 23, 2012 | Televison & Video
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
How to unlock blocked channnels
Hello
There is a common method to unblock the V-Chip settings of a Panasonic TV. After unlock it, you have to reset the V-Chip settings again.
To reset and clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
OK
Jan 19, 2011 | Panasonic CT-36D32 36" TV
My aim tv is also locked. Blue screen and red lock in top right corner. no response from any button
Hello
Put your set in Standby mode. Then press "Power" and "Action" button at the same time and power it off with its front panel power switch. The set should reset to Factory Defaults, and reset V-Chip.
OK
Nov 19, 2010 | Panasonic CT-2789VYD 27" TV
Nesecito el diagrama
No diagram but htis may help since it is very common problem in this TV.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jun 23, 2010 | Spectroniq PLTV3250 32 in. LCD TV
TV WILL NOT TURN ON
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Mar 08, 2010 | Protron PLTV3250 32 in. LCD Television
My Tv power light is not on
Feb 24, 2010 | Protron PLTV3250 32 in. LCD Television
No power to TV can't turn on set. Disconnected power coed and reinserted, still no power. HELP HELP
Feb 23, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Mitsubishi CT-29AC2
I ASK FOR SCHéMA MITSUBISHI TV CT-29AC2
May 24, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
