My computer XP does not recognise seagate db35.3 series 250 gigabyte hdd
  • idast Aug 19, 2008
    Hdd spins at starting and is connected with ide cable, as master on secondary ide. Bios can see it but windows explorer will not.
    Thanks but no go. I have tested the cables on another hdd and they were good, and cmos detected the different drives - but windows explorer will not show the Seagate.
    Brigadier General:
  • 6,966 Answers
If the BIOS/CMOS can auto detect the Seagate 250Gb but Windows can not, then it is very possible that the partition of the said HD is lost. It may be necessary to re-partition. If there are important files, you may want to use a file recovery utility before re-partitioning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
  • 6,487 Answers
Try to right click on any place on your desktop screen, then click New Shortcut and type in F: then try using that drive letter and check if you can access that new hard drive..
Hope that helps.........
  • 1,800 Answers
First if u want to be assure that ur drive is detectabe by windows put it in the place of another drive that alrady working like a cd rom or dvd rom players okay
if the computer regngnize it in the place of another player be assure to format it with FAT 32
if thi post isnt helping u tell me before rating me
so i can help u further!!
    Master:
  • 623 Answers
Go to my computer
right click properties
hardware
device manager
?dvd
scan for hardware changes
    Master:
  • 763 Answers
Try to go on the cmos and configure the IDE's that inserted. like your hard disk it should shows your dvd player device connected from your computer. if not, check the wires connection to the device like sata or ide and the connection power for the device. hope that helps sir!
CHARCOIS
Posted on Aug 18, 2008
    Scholar:
  • 163 Answers
Make sure disk is correct commected and spins at starting.
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
Will this motherboard support 250 gb harddrive ide seagate
is it SATA? it shouldn't have a problem with hard drives unless the plugs are different. if the HDD is sata and you got a sata connection on your motherboard then you're all set
Feb 21, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Cant load xp onto sata HDD
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Jul 12, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a gigbyte GA-MA790XT-UD4P mother board that when I try to install XP on a new Seagate 1TB Barracuda HDD, that it won't recognize during the install process
If your hdd is sata and you have an old mobo , windows xp (onlycvista will) will not recognize it. Integrate sata in xp (use nliteand goolgle how to) or use the flloopy disk to run sata driver
Mar 29, 2009 | Gigabyte GA-K8VM800M Motherboard
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
Hdd not detected
thaurfen the wiz advised me to use device manager to scan for hardware changes, and it worked. I would like to thank him and give him a star rating but I cannot find his posting now. Sorry about that.
Aug 18, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
