Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Front load..error code F H
Keep getting error code F H more and more frequently. now washer will not complete any cycle. there does not seem to be any less water flwoing in during cycles. troubleshoot guide says it is water input problem, but doesn't tell where filters are or how to get at them. any help would be appreciated
  • 2 more comments
  • vinlorri1 Aug 18, 2008
    the model number is 110.45872400. not sure why you couldn't find it. it seems to be a popular unit and is all over the internet. all kenmore or sears says is to have a service tech come out to the house for a large service fee which i am trying to avoid if all i have to do is clean a filter.
  • mealiffe Oct 26, 2008
    Same problem... F H occurs after about 20 seconds into start cycle and then the door won't even unlock. Is there a solution?
  • plazapaintin Oct 26, 2008
    Kenmore Elite Model #45991: Error Code F11 keeps coming up whenever I use a spin above low. Door won't open until I finally trick it to ending the cycle but the clothes are soaking wet. Is this the same problem with the drain? Where is the filter that needs to be cleaned?
  • LG2008 Dec 29, 2008
    Yes same issue, not all settings working. Need a fix.
**Before you begin make sure to turn off either the hot and cold water valves.**
The resolution is to remove the hot and cold water hoses connected to the back of the washer and remove and clean the microfine filters located inside washer's intake valves.
*The purpose of the filter is to capture all of the mineral deposits from harsh or rusted water particles.*
Basically, unscrew the hoses (connected directly to the back of the washer)
Carefully, remove the filters (they are very sensitive and could puncture easliy)
Clean them off with an old tooth brush in soapy water.
Finally, replace the filter(s), hoses and finally turn on the hot and cold water valves and best of all you will save yourself about $125!
Cheers
Posted on Jul 11, 2010
Thanks! the stop and re-start worked for me. I am at a vacation rental and have never operated this model of washer b4. I interrupted the cycle to add soap and got the F H code. Now here's another question, since there is not operating manual here, when do you add the soap for this model? At home in my top load, I start the water, add soap, then put clothes in. This obviously does not work with front load.
Thanks!
Posted on Aug 18, 2008
  • 594 Answers
I can not find your washer or the error codes. please call this number below and let them know that you need the meaning of the code and what to do to fix it.
Product questions
Call 1-888-KENMORE (1-888-536-6673).
please do not forget to rate and comment about your experience with fixya today.
  • Cameron Viseth
    Cameron Viseth Aug 18, 2008
    ok do this.
    select stop (press it 2 times)
    select drain and spin if there is water in the tub.
    reselect cycle and start.
Check the air trap (bottom of tub) on the south end of the air tube attached to the pressure switch (top right rear under the top cover). Mine was plugged with 7 years of crud causing an FH error code, stopping the wash cycle. Great machine - saved hundreds of bucks I suspect.
Posted on Nov 06, 2011
Hi
I took off the panel at the back of the unit. the area where the hoses are attached. there is a small screen filter there. (like the one on a sink faucet). i cleaned it and the washer has worked perfectly ever since. no more FH error code...by the way this means low water inflow.
Posted on Oct 27, 2008
Where it says Kenmore elite, try pulling this out it is a compartment. It holds your laundry detergent,bleach,and fabric softner. The compartment just blends in. Good luck you will enjoy the wash.
Posted on Aug 19, 2008
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
5,382 people viewed this question
Sal De
fordexpert
Robert Rankin
