Question about Garmin StreetPilot c550 GPS Receiver
Downloading a POI Loader for my Garmin c550
I was looking in the manual of my Garmin c550 and it says to get extras such as audio tours of interesting facts on tour or route as well as safety cameras,school zones etc.
I go to the www.garmin.com/extras site where in order to get these features, I am suppose to click on to POI LOADER, but I cannot find where to click on to POI LOADER.
Please help me with this problem.
Thanks..... Doug
  • wil241 Aug 18, 2008
    Help me with the above problem.
I did it here but don't know how to download POIs...
http://www.gpsinformation.org/penrod/poiloader/poiloader.html
Posted on Oct 24, 2008
Trying to connect to garmin.com/us
The GPS itself will not connect to anything - you need to connect it to a computer (that is connected to the internet) via USB cable and then run Garmin Express software from Garmin. The Garmin Express software will alllow you to update maps, firmware and more. The Garmin POI Loader software allows the transfer of customized POI's (Points of Interest) such as geocaches, etc. Check the links below for these offerings.
Garmin Express
Updates Downloads
Mar 23, 2015 | GPS
Tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
on Apr 18, 2010 | Garmin nuvi 250W GPS Receiver
Custom poi doesn't have Go
connect your gps to computer and look at the files in the poi folder. they should be gpx files. When poi loader does its thing it converts the csv files to gpx maybe something didn't work the last time you loaded files.
Nov 14, 2017 | Garmin Nuvi 1450LMT
Im trying to upgrade my Garmin Nuvi GPS system can you help me?
Updates & Downloads nuvi 250W Update Unit Software with WebUpdater Use WebUpdater to automatically keep your operating software current.
Additional Software: Points Of Interest
  • POI Loader for Mac, Ver. 2.1.0, as of Jan 30, 2009, Download
  • POI Loader for Windows, Ver. 2.5.4, as of Oct 08, 2009, Download
Also, here's the link to your Owner's Manual if you should need it.
(Revised. A, Sep, 2008
arrowblack1.gif Download
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | Garmin nuvi 250W GPS Receiver
Mapsource and POi loader can't find garmin device. I am using garmin XT mobile in my Samsung omnia
You don't need either with the omnia's garmin, I tried it also just to figure out the Mapsource and POI is only for Garmin Nuvi's
Mar 31, 2009 | Garmin XT Navigation Maps Software for...
GARMIN 260W
Hi It is more important to know how to add POIs. Here is a simple tip:
1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
Cheers
Feb 13, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 310
To update to the latest requires buying a map update. Too expensive in my book. Garmin does have a POI loader utility that you can get at their site. Various web sites have POI listings that can then be installed. You can also find individual POI listings for such things as all Walmarts at a company's web site.
Jul 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
Having problems with poi loader cant find csv file to be able to download files.unit is a garmin c31o
Here's how you get custom POI files on a Nuvi:
1. Download and install Garmin's POI Loader.
2. Create a folder on your computer, suggest Desktop, with a name like "Custom POIs". The name and location doesn't matter but you have to remember what it's called and where it is.
3. Go online and look for 3rd party POI files. Places like www.poi-factory.com have dozens if not hundreds of files.
4. Select ones you want on your gps to download. Make sure you are getting the files in the correct format. Newer Nuvis use *.csv files. Not sure if the C310 does. Download your POI files into the folder you created.
5. Plug your USB cable into the GPS and your computer. Wait until the driver finishes loading.
6. Run POI Loader and follow the instructions until you get to a screen asking for location of POI files. Point it towards the folder you created. Next tell it to load the POI files. After a few seconds it should give you a message "XXXX data points successfully loaded".
You should now be able to go to POI/Extras screen and see "Custom POI Files". Open that up and your custom POIs should be there.
Apr 09, 2008 | Garmin GPS
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Cameras
Not a chance, they are not part of any map program.
Oct 22, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
293 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
