Question about HP Computers & Internet
I've got a pavilion zv5014ea and it does not charge anymore. It is not aproblem with the charger connection but the power connector linked to the motherboard. Is there any solutions to power up by using a docking station
  • 197 Answers
If you use a dock station that just gives you power to the computer it does not charge it
Posted on Aug 19, 2008
SOURCE:
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Hp pavillion dv4 charging indicator is blinking even if charger is plugged in. and when turned on, suddenly shut downs just a few seconds from turning it on. any solutions to this problem? i'm really...
From the batterycentury.com(http://www.batterycentury.com/hp-pavilion-dv4-battery-p-22931.html) Why your HP Pavilion dv4 Battery light flashing?this migth fix your HP battery Pavilion dv4 problem;
  • Go to your power settings by right clicking on the desktop and select Properties> click the Screen Saver tab> click Power.
  • Under Power schemes select select all of the choices to never.
  • Plug the power supply into the laptop and wait till it reaches 100% and stop charging..
  • Disconnect the power supply and let the laptop discharge completly untill it heibernates.
  • Reconect the power supply and let the laptop charge complely again, then go back into the HP dv4 Battery power settings and resume the previous settings.
...but in your case - that sounds to me like the battery is defective...
Jun 13, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My Acer Aspire One was working correctly untill I powered it off yesterday. Now there is no charge indictor burning, and the power light stays out when pressed. And the netbook does not start up. So there...
Yes, it's either the charger ... the power connector ... the battery (not contacting well, or not charging anymore, or if a Li- Ion battery, it's depleted too low to start recharging anymore), or ... the power supply (circuitry) that's toasted.
Try removing and re-seating each component ... to see if the connection is the problem.
With the power charger inserted, try to power up ... and/or hold the power on for a while ... up to a minute or so, to see if it powers up.... and you get lucky.
Aug 11, 2010 | Acer Aspire One PC Notebook
My lg300 phone doesn't charge anymore.
The connector of the charger to your phone, or the connection part of your phone is spoilt, you'll have to get either of them fix.
May 04, 2010 | Cell Phones
Wont charge anymore? hp dv 4000
Does the computer acknowledge when you plug it in? Are there any status lights indicating AC power? If not then the electrical contacts in the laptop power plug may have broken. If you are not under warranty, you could take a peak inside the case where the connector is and possibly fix it with a soldering iron. In the meantime I'd backup any important data.
Jan 24, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion ZV5000 Charger
HP has a cord that plugs into the right side of the zv5000 that is intended for use with a docking station that they sell separately. The connector has a blade with a bunch of connections, but I only use 2, power and ground. The outermost contacts are power +and-. I bought the cord - re-wired my power cord to the new cord power wires - takes some figuring to determine correct wires - soldered them up and it has worked great for 2 years - much better connector also - squeeze side tabs to plug in or un-plug. This solution was about $25 if I remember - compared to $135 that the shop quoted me to replace the internal MB power connector
Oct 17, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
Open Questions:
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
