I have an HPDV2000
Blue Screen will randonly come onand sometimes restarts it self.
I Do a Hard Drive self test it fails and the comprenensive part or sometimes shut down the system down at around 40%.
Sometimes black screnn that's says operating system not found.
and i do a check disk and will go around 10% and freeze.
Can you help me .Thanks Darla
  • 38 Answers
You need a new hard drive. Sorry.
Posted on Aug 20, 2008
I m not able to install any os in my lenovo laptop
From the description you have a hard drive problem, remove the hardware from the laptop and reseat it back in place, sometimes this is enough to restart the hard drive, if this fails! have a professional test the hardware for possible replacement.
Apr 03, 2012 | Lenovo Computers & Internet
Hard drive crashed
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
NOTE:
The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
How do i open aspire one to check hard drive?
Well..... i understand that your notebook has dropped and not able to boot with an error.. to isolate this issue i strongly recommend to the steps given below 1. restart the noteboot or press the power button to restart...... 2.Now press the function key F2 this takes you to BIOS which u can see the options in a blue screen. 3. Here in BIOS mode you need to perform HDD self test. If the test failed to examine the hard drive then you need to replace the hard drive.
Hope this could help u...... For further quries give me reply...
Jul 22, 2009 | Acer Aspire One AOA150-1504 Netbook
Sir as i m installing xp2 pack as os within a week i m getting a system 32 error nd a blue screen error where the system gets restarted and a message appears stating the ''THE WINDOWS DELAY WRITE...
run a hard disk self test from the bios.....if it fails then you have to replace your hdd and if it passes then reinstall the OS from another disc
Mar 17, 2009 | Dell Inspiron 6000 Notebook
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Laptop help
yes, may be the hard drive... so goahead and run a test on hard drive....
try going to bios setup.... from the main menu in bios... highlight the hard drive... maybe displayed in first drive, or second drive...push Enter... and from the list select an option smart self test...
There would be two test's one is smart self test and smart extented self test... first select the smart self test... it would go up to 5 min... if it is pass go to second test...ie., smart extended test...it would go upto an hour.
If first test fails... no need to run the second...directly replace the hdd... but if pass go to second.. and check the hard drive..
As you said you are using UBUNTU.... try install it again.. if hdd both test pass..
Aug 21, 2008 | Computers & Internet
Problems with my HP DV2000
replace the HDD with Proper one for ur laptop.
HDD: Hard Disk
Aug 18, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
