Question about Ricoh Aficio 2022 All-In-One Laser Printer
Error Log Cannot store data of this size. Document Server
Good day
I have some print jobs that don't store on the document server when told in the printer driver. They reset and I get an error message on the configuration page = Cannot store data of this size.
I am aware of the various machine limitations. The HDD was free of data at the time of testing.
Model is Ricoh Aficio 2045e
  • Ricoh Master
  • 2,794 Answers
The document server portion of the copier not only has limitations to it but it has compatiblity problems with it as well when dealing with mulitiple pages. The SODIMM card could be set for 64mb on your copier and the buffer is too small to work with it. It doesn't work the same way as a fiery server does on todays copiers.
Ricoh tech support has told me there are three ways to use the scanner:
1) Scan to e-mail.
2) Scan to ftp server.
3) Scan to document server using a seperate PC as the server.
4) Scan to a local computer using Desktop Binder.
www.ricoh-usa.com has software to do 3 and 4. #1 can be setup by adding the smtp server to your copier in the file interface section by pressing the user tools/counter. You have to have the IP address to the smtp server in order to get it to work. You can contact your internet provider to get that.
Using the document on the copier is for temporary storage and isn't designed to handle big jobs to it as well. You can experience storage problems as well if your print server is full or you are storing faxes to the memory.
The memory can be updated to the copier as well. It can read a SO DIMM PC100 card up to 256 MB. It's an older memory module that they use on older notebook computers. You can get them at computer stores or get them through PNY.com.
Posted on Aug 27, 2008
Our Xerox machine says controller error error 116-324
Someone printing a web page or a document with text/image that the machine does not recognise. Delete the job from the server or PC from where it is being forwarded to the machine then power on machine. If the job is stuck on the machine queue then power on and as soon as the print job appears in the queue on the machine you need to deleteit. May have to log in as admin.
Jul 19, 2016 | Xerox Phaser 6600 Color Laser Printer...
I would like to retrieve a document from the printer's cache, is this possible?
No it isn't. The printer memory is transient. It collects the data from the printer and then feeds that data until the document is printed. When the document is printed, the data is gone.
The exception might be if it is a network printer that is connected to a server. The server will hold the document for a a predetermined time.
Nov 05, 2015 | Office Equipment & Supplies
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
Error Message says "Cannot Print Booklet or Magazine due to Mixed Color Modes"
Might be a bug in the software.
Suggest try re-download again.
Dec 02, 2017 | Office Equipment & Supplies
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Document Server issues
The 2022 has a very limited area for storing document in the copier. It has several bugs in it as well if you put them into PDF multi page mode. The best way to store them is to use an ftp server or scan to email. SMP server will work as well.
That way the Documents can be kept off the copier and stored into an area that is easier to organize the data with.
Document server wasn't designed to be a document server for long storage use.
Aug 13, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
373 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
