Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
Cant set alarm
Need to know how to set the alarm on my rm313pu alarm clock
Http://www.oregonscientific.co.uk/files/manuals/RM313P.pdf
Posted on Sep 08, 2008
SOURCE:
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
My alarm clock does not distinguish between AM and PM. it simply does not turn on the sign for either, so i cant tell if my alarms are set for am or pm...kind of important.
Sounds like a display problem where the indicator isn't working. This might be a bad connection or it could be the display itself or the driving electronics. In any case, it would probably cost you more than the clock radio's worth to have it repaired (assuming you find someone who'd take it for repair in the first place!).
Here's a "solution", though. Set your alarm for a time only a couple of minutes later than the current time and wait around. Depending on whether or not the alarm sounds, you'll know if it's set for AM or PM. At least you'll be able to keep using it until you decide to replace it.
Oct 06, 2010 | Memorex iWake MI4004 Clock Radio
Hi i have a rca Clock Radio RP5435C i need to know how to set it.
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
Jul 19, 2010 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
How to set alarm
Hold down the button labelled 24hOFF for several seconds, the alarm hour digits will flash, adjust using up down arrow buttons and change to minutes by pressing 24h button again.
Plus your manual is below. rm313pu
Oct 29, 2009 | Oregon Scientific OR-RM313PA ExactSet...
Cant change clock setting of pioneer deh 4050UB
I dont know what deck you have but you can try this. Turn off the deck by holding the source butten then hold the function butten you will be able to turn on and off the warn for the alarm along with the clock.
Mar 24, 2009 | Car Audio & Video
I cant set the music station for my t622h alarm clock
Hi - You can download the manual by clicking the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Timex Auto-set Clock Radio
Setting the alarm
Aug 18, 2008 | Oregon Scientific OR-RM313PA ExactSet...
Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Mar 03, 2008 | Audio Players & Recorders
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
341 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Tom Chichester
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
