Most likely this is caused from a pump leaking and then shorting out the control board. If you lean your machine back look under the right front corner and locate the pump. (will look like a black box with a fan attached.) You will most likely find white residue on the pump. if you do, that means the pump has leaked and blown the board. you can order the parts at www.fisherpaykelparts.com.
This is usually a sign the controller module has expired.
