HP laserjet 4280 - Cartridge 60 - How do I reset the ink levels and which holes are for which color inthe coor cartridge?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..you'll need new ink or cartridges, of course..and they are color coded usually..
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
HOW CAN I RESET INK CARTIDGE LEVELS ON HP DESKJET 3510
When you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this 'low ink' phenomena.
Additionally, severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Feb 18, 2013 | HP PhotoSmart C4480 All-in-One Printer ...
Trying to use a re-filled ink cartridge HPf4280
I seem to recall that these cartridges are chipped and you need to get a chip resetter. Look on the base to see if a small circuit board is present. If so then you have to get it reset or buy a new cartridge.
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | HP LaserJet 4200 Printer
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
Hi, I have an HP F4280 printer and the orange light of the color ink level is always lighting so i can't print anything (I am sure that my color cartridge is not already empty). What can I do? Oh yeah,...
There is only enough ink in the HP 60 cartridge to print approximately 200 pages. Also, the ink stored in the cartridge can dry quickly even it it's not used so you may be out of ink or the ink in the cartridge has dried up. Refill your cartridge with a kit or replace it with a new one. The ink level indicator is only an estimate any way. See pg 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jun 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Jan 29, 2009 | Office Equipment & Supplies
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
1,033 people viewed this question
jasbo
jasbo
