Problem with new calls
I have a Panasonic high speed laser fax and copier Model KX-FL541 and in the little window it shows 21 new calls flashing. I do not know what this means and I do not know how to take care of it.
    Genius:
  • 2,120 Answers
Unplug and replug power cord.
Posted on Sep 01, 2008
Panasonic kx-mc6020 showing error call service4
Follow this link to diagnose AND TROUBLESHOOT:
http://tsn.pstc.panasonic.com/viewing/NA/KX-FL541/SVC/s0605060000.html
CALL SERVICE 4" means that the FAN does not run or the running of the FAN cannot be detected normally.
The running of the FAN is detected by IC 605-91pin. "CALL SERVICE 4" is displayed when it detects NG five times continuously.
After repairing, copy five times.If "CALL SERVICE 4 " is displayed,check again.
Oct 14, 2013 | Panasonic KX-MC6020 All-In-One Laser...
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
How can I reset Replace Drum on the Panasonic KX-FL511 Fax?
First of you will have to purcahse a Panasonic Drum Unit for you fax.
Inside the drum unit yu will have detailed instructions, you will open up the fax in the front take aout the old and install the new.
Here is a link to a helpful guild
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/How-To-Guides/model.KX-FL511.H#ts
Good luck
Nov 05, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Fax Problem KX-FL541
your scaner is dirty,you have maybe nsome stuck in the scanner,or correcton fluid gooes from document to scanner lamp,check is all ok ,if everythin clean,your scaner lamp has a damaged ,try to change it or call service man
Feb 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
64 people viewed this question
jasbo
jasbo
