Question about Cameras
When we plug the camera into the macintosh it wont recognize the camera
  • danaestrada Nov 14, 2008
    The computer doesn\t recognize the camera and I can not download the software
  • golflover1 Dec 28, 2008
    I have the same problem.  I plug the camera in to the USB port just like any other camera and turn it on, but it's not recognized.
Well after a bit of trial and error, I found a somewhat consistent solution.  Here are the steps:
1.  While the camera is off, plug the USB cable into the camera (Don't plug the other end of the USB cable into the computer yet)
2.  Turn the camera on and press the mode button
3.  Navigate to the Camera icon
4.  Plug the USB cable into the computer (the camera icon will change to the USB screen)
5.  You will notice nothing happens!
6.  Unplug the USB cable from the computer
7.  The camera screen switches back to the Camera icon
8.  Plug the USB cable back into the computer and a VTech 773 icon should show up on your desktop.
9.  When your finished copying pictures to your hard drive, drag the VTech 773 icon to the trash.
I don't know why it works but it worked 9 out of 10 times for me.
Let me know if you find a simpler solution.
Posted on Jan 06, 2009
That's the key. Plug the camera directly into the Mac. Don't go through a hub or USB extension or any other device.
Thanks.
My macintosh powerbook won't recognize my powershot sd1100
Use a card reader to download to a folder you create on your desktop.
Feb 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
When I place the camera on the cradle in USB mode, my Macintosh computer (running OS X 4.9) does not recognize the camera; no icon appears on my computer screen. This is a new problem.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Oct 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
What do i do
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Usb not recognizing camera
you have to install drivers on your computer before it will recognize it.
go to
http://www.fujifilmusa.com/JSP/fuji/epartners/
ServiceSupportProduct.jsp?prodcat=710738
and install the usb drivers for your operating system ie windows xp
Your computer will recognize it after that whenever you plug it in:)
Feb 23, 2008 | Fuji FinePix A330 Digital Camera
Sakar Digital Camera 16379
I am sorry sir this particular camera is not compatible with Macintosh because it only has a windows version software u have to use a windows operating system in order to download the pictures to the computer because this camera doesnt take a memory card thats the other reason y u cannot transfer the pictures using macintosh
Dec 31, 2007 | Sakar Kidz Cam Digital Camera
IEEE1394 Fire wire stopped working
I'm supposing here that you're using a Macintosh computer, because the firewire port is only supposed to work with a PV-GS320 when the camera's downloading into a Macintosh computer. (For computers operating under Windows it's supposed to download through the USB port instead.) And:   I'm writing you because I'm having exactly the same problem that you described!
The first 2 movies I took downloaded from the camera VERY easily, but the 3rd one refuses to download at all (the computer doesn't recognize that there's anything to download). I also tried the camera on another computer and the problem was exactly on my own computer even though the updated levels of the operating system and of the iMovie software in the computer were slightly different.
I've asked Fixya for help on 17 May 2008, and never have received any response at all (despite having paid in advance for “Premium” technical support); so Ive given up on them and am working the problem elsewise.
My e-mail address is HyimL@jps.net and my phone number is (310)374-6133. Please contact me and maybe we can help each other.
Hy Levy
Apr 05, 2007 | Panasonic PV-GS300 Mini DV Digital...
"Disk is unreadable" message when inserting a CF Card - Macintosh OS 9.x
Certain system software is needed to allow a Macintosh (running Macintosh OS 9.x or earlier) to access mounted compact flash cards. If this required software is not installed the computer will not be able to recognize the card and will display the following error: DO NOT press the "Initialize" button, as this will completely erase the card and destroy all images. Click the "Eject" button and then enable the necessary system software. The following Extensions or Control Panels need to be activated: File Exchange - Control Panel Foreign File Access - Extension The "Extensions Manager" Control Panel (found under the "Apple" menu) can be used to enable these items. After switching them "On" restart the computer to apply the changes. After restarting the computer insert the card and it will mount on the desktop like any removable disk.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
569 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
