Question about Toshiba Satellite A135-S4527 Notebook
Toshiba A-100 laptop asks for bios pass word upon starting
The screen of laptop gets black and wants pass word to be entered. I am not able to access inside.
I had this issue my brother took it to a computer place and they had to enter a BIOS password, it did not cost anything hope it helps!
Posted on Aug 18, 2008
6ya staff
SOURCE:
How can I fix my laptop I a connected to the internet, but have no connection through internet explorer, or any browser, I have re- booted, and removed Norton add on, but still no joy can you advise.
If you are using a wireless connection you will have to put enter a pass key to allow it to get the internet. Look on the lower right corner of your screen and you will see a icon for the internet, click it and then open internet network and sharing center. Then click on connect to the internet it will give you a list of access points, choose yours and then enter your pass key and click ok. If you are using a network cable just plug it in the laptop and it should give you the internet with no problem.
Sep 18, 2016 | Acer Aspire Series 5715Z 5720 5730 9100...
Need to reset the power on password on a compaq presario cq62 can't get pass the first screen. as soon as i start up the computer get the screen enter password.
These WEB sites can help you remove the Power On and BIOS password.
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Jan 27, 2013 | Compaq Presario CQ56-115DX Laptop
If I reset my router, do I need the CD to reconfigure or change the password
You don't actually need the CD to reconfigure your router or change the password or anything related to your router. So long as the router is connected to your computer via ethernet cable you can access the browser configuration page of your router.
1. connect your router to your computer via ethernet cable
2. If you are using Windows XP
- click start
- click run
- type cmd
- in the black screen type ipconfig and press enter
- look for the default gateway (example 192.168.1.1)
- Open Internet explorer
- type in the address bar: http://the default gateway (example http://192.168.1.1) then press enter and it'll ask you for the password
- usually the username is blank and the password is admin or the username is admin and the password is pass or password
If you are using Windows Vista / Windows 7
- Click the pearl button
- Click on start search at the bottom of the pop-up window
- type cmd (don't press enter yet)
- right click the black icon on the top of the window after typing cmd
- click on the run as administrator
- click on continue if there's a prompt
After successful accessing the configuration page you can now configure your router freely.
Jan 11, 2010 | Gateway Wireless-B Router (wbr-100)
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
I lock my cell phone and forgot the code how do i reset it the phone is a i 465
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code.
2. Press the MENU button. The screen will show, Enter Security. Try both.
3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR
Enter six zero's (000000) and press OK.
*If successful, the screen will display, Phone Unlocked.
*If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions.
5. Do not change the Unlock Code.
Oct 10, 2009 | Motorola Mobility Clutch i465 Cell Phone
Asking for password sata port pass
This is a "security" feature, to protect the files on the disk-drive from unauthorized access.
The computer supports "full-disk" encryption of each disk-drive inside your computer.
So, what password did you set when you first initialized this disk-drive?
If you don't know it, there's nothing you can do -- all the files on the disk-drive are _NOT_ accessible to you.
Jun 01, 2009 | Acer Aspire 5050-3242 Notebook
Cannot get my laptop to the screen to enter password
Try to restart your laptop, when you see the IBM Thinkpad logo press F8 several times until it gives you a black screen menu with some option. Try the "use last known good configuration" first and see if it works, otherwise try to access in safe mode. Once you're in, try a system restore, and bring the computer back to a date you think it should work.
To access System restore you go unser start - programs - accessories - system tools.
Good luck
Mar 31, 2009 | Lenovo ThinkPad R61 Notebook
Bios remove password
How to clear an unknown BIOS password. Information and help with clearing an unknown BIOS password. ... On the computer motherboard locate and remove the CMOS battery .
Good Luck/Please dont for get to Vote.Thank You.
Dec 15, 2007 | Dell Inspiron XPS M140 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
