Need plug connections for tape/radio . made for nissan
  • 682 Answers
From radio shack near you.
Posted on Aug 18, 2008
SOURCE:
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Feb 03, 2016 | Nissan Cars & Trucks
I have a Pioneer model CT-F2121 want to connect it to my Radio amp. I has two ports at back of Radio which is marked "switched" and "Unswitched" Radio is a Sansui model 210SS multi receiver. I have tried...
The deck if in working condition can be plugged into any AC wall outlet or the two AC outlets on the receiver. This is only for power, The Line outs and line in also have to be plugged into the Tape in and record out on the receiver as well. If the CT-F2121 need repairs that is what needs to be done first. Probably a whole set of belts.
Aug 12, 2013 | Pioneer Audio Players & Recorders
Radio wiring colours nissan nivara 2006
fastest and easiest way to do it would be to get used plugs from the junkyard and then get a wire harness for the radio to fit it, most auto parts stores carry the radio harness.
Oct 16, 2012 | 2006 Nissan Navara 2.5
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Can I connect my YP-U3 MP3 player to a car stereo? If so, what kind of connection lead will I need?
well it has a regular 3.5 mm jack. you can get a universal fm radio transmitter that plugs right into it, tune your radio, and listen in. I on the other hand, have a car with a tape deck, and just used the tape adapter from an old cd player i had, that plugged right into the headphone 3.5 mm output.
Dec 31, 2009 | Samsung YP-U3 MP3 Player
No radio stations comming in, antenna okay, i think
have u checked to see if the antenna is any good?
Jun 11, 2009 | Car Audio & Video
94 nissan 300zx factory radio
There are some small clips that need to be removed. So be careful with them.
Take a look at this picture.
http://www.300zxclub.com/attachment.php?attachmentid=16848
Mar 25, 2009 | 1994 Nissan 300ZX
CONNECTING TAPE RECORDER
I assume you want to record from a tape recorder/player. If not, leave a message, but it will be a similar cable and connection.
If your tape recorder has a headphone jack, you can connect it to your sound card with a special cable. The headphone connectors are sometimes different sizes. It could be either a 1/8 inch, 2.5 mm or 3.5 mm plug. Your local electronics supply store (Radio Shack?) should have the cable you need. (I'd take your tape recorder with you, if possible.)
Jan 02, 2009 | Soltek SL-KT600-RL Motherboard
Sirius question
Yes it should be very easy with use of the ear phone jack - depending on the model of course but generally all you need is an ac/dc power supply, the antenna connection, and for connection to receiver you can connect via FM or hard wire.
FM: as in your car pick an FM station frequency that is clear (no station on it) lets say 88.1 then set your home receiver on 88.1 and there you have it.
DIRECT: purchase a stereo 3.5mm headphone cable with two RCA male plugs at the other end. A faily common cable found in dollar stores or for five times the price at Walmart/Radio Shack etc.. Plug the 3.5mm plug into the 'headpone' jack of the satellite radio and the RCA plugs into the rear of your home receiver - usually a 'aux/line in plug" or "tape in" plug then turn the knob on the receiver to "aux or tape" selector. Bingo you should hear satellite radio all over the house....if the volume is UP! Take care Frank
Sep 05, 2008 | Sirius Satellite Radio Receiver
Installing a car stereo
you must connect the wire to turn on the amp
Apr 03, 2008 | Durabrand WD268 Cassette Player
20 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
