Question about Philips Office Equipment & Supplies
Have no disc to install the device - Philips Office Equipment & Supplies
Philips does not support this printer and does not offer a driver!!
Posted on Oct 18, 2009
  • Philips Master
  • 13,434 Answers
The software is always available on the makers website.
Posted on Aug 18, 2008
SOURCE:
Where does the driver disc for my Sylvania Turntable Model STT008USB go?
The turntable itself does not require a driver. The PC should identify it when you connect it to the USB port. The startup disc contains the Audacity program that you need to use to convert the analog audio from the turntable to digital audio format. Install the Setup disc in your PC's disc drive and if AUTORUN doesn't automatically start the install, explore the disc and click on the SETUP.EXE file to install Audacity. If you are trying to do this using a netbook or other device that does not have an optical disc drive installed, you will either have to get and external optical drive or, on another device that HAS an optical disc, copy the files from the startup disc to a USB stick and run them from there.
Nov 03, 2016 | Sylvania Televison & Video
Where does the start up disc for the Sylvania Turntable Model STT008USB go?
How do i install a WC4750AFB web cam without disc
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 17, 2012 | Gear Head WC535I Webcam
How do i install my webcam without the disc
How do i install my webcam without the disc..
May 20, 2010 | Xtatix XCA-PP2A Webcam
How to install my webcam without using the installer disc
if your current o.s. recognized your device and it installed the required driver then you dont need the installer disc, but if windows required the disc you have no choice but to use the installer disc, you wont be able to use your device unless you installed the device driver
Nov 23, 2009 | Microsoft LifeCam VX-1000 Webcam
Webcam
Make sure you have the drivers in the disc that came with the device. After inserting the disc to you pc, do not run the set up. Open MY COMPUTER, right click your cdrom drive and click EXPLORE. You must see DRIVERS in the folders. If you have DRIVERS on the disc, try to install the drivers manually.
You can only install the drivers if the computer is detecting the webcam. Go to DEVICE MANAGER and see if your webcam is listed on the devices. If pc is detecting it, you should see the webcam with a YELLOW QUESTION MARK(meaning drivers are not installed). Right click the webcam and click update drivers. Select install from a list of specific location. Select DO NOT SEARCH, I WILL CHOOSE THE DRIVER TO INSTALL. Select the HARDWARE TYPE(imaging devices), then click HAVE DISC. Click BROWSE, select your CDROM DRIVE, select the driver folder of the webcam. The drivers should be copied to your pc.
Good Luck
Mar 16, 2008 | Computers & Internet
Lost disc for download
what is the make and model of you camera and i'll c what i can do.
Dec 16, 2007 | Philips J44414
41 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Damen Wong
Damen Wong
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
