Question about Lexmark Office Equipment & Supplies
I have a lexmark x3480 printer and have just changed the ink cartridge- for exactly the same lexmark one as was in before. Now the printer comes up as 'Cover Open' even though the lid/cover is down. Cover Open means that I cannot print and the machine will not turn off. I have deleted and put back on and done all the usual things to make it work. This is the first change of cartridge since I bought it so I am not impressed. At the moment I am working through and trying not to become annoyed. Rachel
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
You may want to run a clean head cartridge routine..and recalibrate them..
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Lexmark x3480 catridge incorrect
It could be faulty cartridge issue. Try to replace a new genuine cartridge to determine if the other is faulty.
Mar 16, 2012 | Lexmark X3480 All-In-One Printer
I changed my ink cartridge, and now it has cover open displayed but the cover is closed
when you open the lid there is a small white piece of plastic witch should be attached to a very small micro switch .this keeps coming off for some reason .you have to find it and reattach it to the switch that is just right of the middle of your printer .hope this helps
Oct 02, 2010 | Lexmark X3480 All-In-One Printer
New cartridge fitted still reads low ink.lexmark x3480
Try this... Unplug the printer from power and restore power... also, reboot the computer. if that doesn't work, try reinstalling the cartridge or reinstalling the software. If there is an option to ignore these messages, it will be in the options srction of your printer manager program.
Dec 29, 2009 | Lexmark X3480 All-In-One Printer
How do i change the cartridge on the lexmark 3480. I have lost the manual.
When you open the section at the "waistline" of the machine the inks will center themselves automatically giving you clearance to change them.
Oct 07, 2009 | Lexmark X3480 All-In-One Printer
My printer says cover open after I changed the ink cartridge. The cover is NOT open
the sensor that detects if the cover was opened has been triggered. it probably needs to be reset in the menu accesed on the front panel.
either that, or the sensor itself has come loose inside the printer. check that the part has not come loose.
Sep 22, 2009 | Lexmark X3480 All-In-One Printer
Lexmark x3480 cartridge missing fault
First make sure that the refill cartridge is the correct one.
Example: X3480 printers: #2 cartridge
If so than take the cartridge out and clean all the contact points with a dry cloth. These points can sometimes get dirty, especially by refilled cartridges. reinsert the cartridge and than unplug the printer and plug it back in after 10 seconds.
I can type out how to troubleshoot this, but it would be easier for you to open the link below. This will give you step by step instructions on how to do this.
http://support.lexmark.com/perl/support/support.cgi
Let me know if this does not work for you. Good Luck!
Mar 13, 2009 | Lexmark X3480 All-In-One Printer
How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
Lexmark x3480 cartrige incorrect message
I had the same problem. Downloading and running the patch program solved it for me. Follow the link below!
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:570:0:0&docid=ENUS25374
Regards Robin
Oct 31, 2008 | Lexmark X3480 All-In-One Printer
Lexmark X3480
There are 2 possible problems, or the cartridge is a refilled one or some problem by the cartridge itself. Try to change the cartridge.
Nov 10, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
