Question about Hotpoint First Edition WMA12 Front Load Washer
Hotpoint first edition wma12
Evrytime i turn the washing machine on the electrics trip
  • internet73 Sep 15, 2008
    My Hotpoint First Edition 1200 is also causing the circuit breaker to trip. It has the motor type 904/1158/10; if the motor is disconnected then the washing machine can pump out the water ok, but as soon as it the motor is connected, it trips the breaker. The motor appears to have overheated as the plastic cases over the brush connectors have melted.
    Champion:
  • 203 Answers
Thats the problem its arking and making the breaker trip. if this helps please rate joe
Posted on Nov 21, 2008
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
Jan 13, 2011 | Hotpoint First Edition WMA12 Front Load...
How do we empty the filter on Hotpoint WMA 12?
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint first edition WMA10 making a bangin noise during wash programme. Cannot find filter in order to clean. trishisfit2000@yahoo.co.uk
I have the same model at work only under the frigidaire branding. The shock mounts for the
drum are made of plastic and can break (especially if the unit is moved without the
shipping screws) If one breaks the unit will make a clunking sound.
Dec 06, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Jan 04, 2009 | Hotpoint First Edition WMA12 Front Load...
No instructions
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint ultima wma75
sounds like the filter is blocked you can take the filter out and clean it and check the hole for lint a sock or a coin etc. if this helps please rate me joe
Aug 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition WMA12 Front Load Washer Logo
325 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
