TH42PWD6 7 blink shutdwon
Hi, I have a Panasonic TH42PWD6 Plasma Display and it has started to shutdown after about an hour, sometimes less. Just before it does the power light blinks 6 short then one long - Do you know what this code is for please?
  • Anonymous Feb 27, 2009
    I have the same problem just started happening...
Hi, I have a Panasonic TH42PWD6 Plasma Display and it has started to shutdown after about 2 seconds.It blinks 6 short then one long - Do you know what this code is for please?
Posted on Jan 22, 2010
Jake I have a 52 inch Panasonic plasma tv that will only run the fans for a few seconds and shutdown red light blinks 10 times and repeats.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 10, 2015 | Panasonic Televison & Video
What do 7 blinks indicate?
The Vieras have standby codes that are not published because few Plasma TVs are serviceable by owners. Power surges will cause the blinking sometimes and the only remedy to the owner is to unplug the TV for a few minutes to let the power supply reset and plug it back in to see if you still get the shutdown mode blinks. If you do, the only remedy is to contact Panasonic at 1-877-95VIERA (USA) or 1-866-330-0014(Canada)
Feb 19, 2015 | Panasonic VIERA Televison & Video
How do i get my panasonic tv out of protection mode
the set is shut down becuase of an issue. Does the power light blink a certain number of blinks/ If so let me know the number of blinks and I will assist with possible cause of the protective shutdown.
Feb 19, 2012 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
Hi, Would you buy a used panasonic TH-37PX50U?
Must check tv carefully for tv images burn in problems,plasma tv have that problems alot.This tv have major issues are power shutdown alot and power supply will not sustance and flashes it power light indcation.Have to unplug awhile like an hour replug back to get tv to work again.If u have chance to used it like 5 hour a day like for a week have warrenty for a week for a return it and get 95% of ur money back.Used it for a week about 5 hrs every day no power shutdown and no power LED light indication flashes i whould buy it.
Aug 28, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
How do I reset my panasonic tv. it blinks red and
You need to count the number of times it blinks in succession - this is the TV's trouble diagnostic system that pinpoints the area of failure. Sometimes, if you unplug the TV and leave it for a few hours, it will power back up.
Jul 10, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
355 people viewed this question
Top Televison & Video Experts
Electro Med Services...
