Question about HP Pavilion dv2120us Notebook
Disassembling the lower case hp dv2120us
How can I disassembling the lower case hp dv2120us?
screw locations?Photos?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
Problem disassembling Braun 4700 series razor
This video should help you in your quest to disassemble your electric shaver
Jan 24, 2014 | Braun 4775 Electric Shaver
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
To: parrotheadpc ... In response to my HP laptop DV2120us with lines ... you asked me to take the battery put and remove 2 shiny screws there are not any shiny screws and under the battery there are 5...
Yea, some have shiney screws some have black....the screws that are in the bottom where the battery sits, there may be 3 I think, they should be straight across.
Aug 31, 2009 | HP Computers & Internet
Describe your HP Pavilion dv2120us PC Notebook Problem dvd drive not working
try whether cds are working in it and use an good dvd lens cleaner
Jul 22, 2009 | HP Pavilion dv2120us Notebook
My Royal SovereignARP-3012 lower blower fan wheel broke
This is a difficult repair and no easy cake at all. The one internal part you can order from Royal Sovereign is the lower blower wheel. Perhaps this is because it breaks easily. Begin by draining the unit by removing the rubber plug at lower left. Remove 14 (count them) from the back. Remove additional positioning screws that hold the case side to the metal frame. Take out the two screws on the underside of the outer casing. Unclip the plastic tie that holds a temperature sensor to the rear radiator, and remove the the sensor gently. Spread the casing gently apart and push it away from the chassis a few inches. Reach into the front and unplug the three electronic connectors that link the display panel to the chassis. Note that the two leads that go to the lower part of the chassis go into positions 1 and 3 - the middle connector is not used. Now remove the casing entirely. Take a photo on all sides for reference and get some masking tape ready. You will see an upper blower casing and a lower blower casing, around which are arranged the condenser and two radiators, held in place by four press-formed metal chassis frames and two plastic chassis supports. Do not proceed until you mark where all the screws into the metal supports go. Failure to do this may end up with putting chassis support screws into holes meant for the back panel, making it impossible to reassemble the outer casing. Remove the grounding wire on the right side facing the rear. Tape the screws to the chassis part and note the color of the leads. Mark the location of the screw so you do not put it in wrong place on re-assembly. Do the same with the double green and yellow wires connected to the other side. Disassemble the bracket holding the white metal electrical condenser, noting carefully how the bracket is designed to clamp the condenser in place. Remove all the screws holding all four corner chassis supports, and mark exactly where the screws go. Stick these screws to a piece of tape and label it. Remove all screws holding the upper plastic chassis frame, marking screw locations carefully. Note that some of these screws hold the upper blower casing in place. Stick these screws to another piece of tape and label it. Working from the rear, and using a long phillips head screwdriver, remove two screws that hold the base of the upper blower assembly. Check gently to see if the assembly is now loosened and can be lifted but do not lift it yet. Remove any other screws that impede. Remove the uper chassis support carefully. This is a tricky move, take your time. Remove the tape that holds wiring on the middle plastic chassis support member and put it somewhere you can get it again, you will need it on reassembly. Once the upper blower assembly is removable, lift it EXACTLY vertically to clear the cleats at the base, then carefully rotate it towards you and place it upside down in front of the unit. There is just enough wire to allow you to do this. Remove and tape screws as needed to liberate the middle chassis support member. Remove and tape the two screws that hold the lower blower casing to the deck chassis support. This is where it gets tricky. Remove the middle chassis support but be very careful to support the upper radiator as you do so. Remove and record the location of any other screws that hold the lower blower casing. Tip the upper radiator as little as possible to allow the lower blower casing to be lifted up out of the chassis floor, and out to the side. tis is a difficult move and it is easy to damage the fins of the radiators. Remove the front of the lower blower casing, and remove the blown-up old wheel. Put the new blower wheel onto the motor shaft and make DAMN sure the nut is on tight. Otherwise the wheel will slowly travel up the shaft, rub against the radiator in front and you will have to do it all over again. Reassemble in reverse order. When you re-connect the wiring of the outer casing, be sure to connect the lower wires in front into positions 1 and 3, leaving the center blade open. You will be glad you recorded the exact location of every screw, trust me. It took me seven days to figure this out, even after worming out the service manual and an exploded view from the company (both useless for this repair except for debugging misplaced electrical connections). Easy cake indeed.
Jun 04, 2009 | Royal Sovereign ARP-3012 Air Conditioner
Ram capacity on HP Pavillion dv2120us
nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Oct 16, 2008 | HP Pavilion dv2120us Notebook
Laptop dv2120us
There is one screw on the bottom of the machine that removes the CD right above the memory cover. It may even have an icon of a CD for it. then it should slide out the side.
Dec 20, 2007 | HP Pavilion dv2120us Notebook
No Display
First make sure everything else is getting power and operating okay, and that it is only the LCD display that is non-functional.
If you get no video signal or power at all, even at boot time, you probably have a dislodged ribbon cabling or power connection. Usually when LCD monitors go bad they show colour banding or all white, etc., but usually continue getting power.
As a last resort, try disassembling the lower case (with the power disconnected and the battery out of course) to expose the LCD monitor mounts, and then following the wiring from the screen into the laptop and check for anything loose or disconnected. You could also have a loose ribbon cable going into the LCD array, which will require disassembling the LCD cowling and mounts.
If you are handy and comfortable with electrics and find nothing loose, put the battery in and test the power line going to the LCD backlight, which should be getting above 7V (I think). Below that and you either have a bad video controller or bad wiring/solder joints somewhere. Otherwise, if the unit has been dropped or had a hard life generally, it could also be the connections between the LCD connector bus on the monitor array and the array itself. As a last resort, try unplugging and reconnecting all ribbon and connector cables, cleaning the exposed brass coloured runners lightly with rubbing acohol or even a pencil eraser.
Good luck...
Oct 16, 2007 | HP Pavilion dv2120us Notebook
Computers & Internet Logo
280 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
