Question about Cameras
Camera refuses to switch on, makes bleeping sound and cuts off.
  • rayz3 Aug 18, 2008
    I tried what you suggested but no result,lens dose not retract and still is beeping and cuts off.
  • Anonymous Nov 13, 2008
    my canon power shot A580 will not come on i have put new batteries in it
    Brigadier General:
  • 6,966 Answers
this might be indicative of a weak battery.
In some instances even if the battery is new or fully charge, the same symptoms would be exhibited. If this is the case, it is probable that the battery contacts needs a bit of cleaning/scraping. Additionally, it may require slightly bending the said camera's battery contacts to ensuire a bit more pressure towards the battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
  • Louie  Role
    Louie Role Aug 18, 2008
    Hi again,
    Your initial post that I responded to did not include "lens does not retract" which makes it an entirely different problem.
    The correct procedure with this new information would be to dismantle the erring lens assembly and clean the mechanism. Sand, dust or foreign material lodged between the moving parts would and could prevent lens retraction. This condition prevents the camera from correctly initializing itself. Having said this, perhaps your best bet would be to seek the services of a qualified professional.
    Jarring the lens loose might work but then again might also compound the issue.
Does anyone know what a two beep error code means on a shoprider scooter? It runs for a short distance and then cuts out.
Hi Sara ,what is the bleep code , bleep then a pause then bleep , how many bleeps before a pause? or is it continuous ?
Regards
Rob
Feb 04, 2016 | Shoprider Health & Beauty
Freezer keeps going off
ensure the rear vents are clean of dust and hair....
Tallon41
Sep 07, 2012 | Admiral 26 cu. ft. Side-By-Side...
Advent Sienna 500 won`t switch on and keeps bleeping
First thing is to identify beep codes.
Beep Code Descriptions
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
Aug 25, 2012 | Computers & Internet
Lcd tv makes a continues bleeping sound
Just cut the power by removing the electrical cable and turn it off for 1 hourthen re turn it on
Feb 27, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Playing a game system just shuts down and now the power indicator is blinking and wont turn back on and when it does it cuts out again?
hello have you tried resetting it take power lead out of the back then reinsert it back in while doing this press and hold standby button on the front of the ps3 you will hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset fingers crossed
regards
shaun
Dec 03, 2010 | Sony PlayStation® 3 (60 GB) Console
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
Samsung PL 50 lens stuck half way
mechnism of the lens is deffective,get it serviced.
Mar 29, 2010 | Samsung PL 70 SL720 Digital Camera
Ricoh GR lens won't go back in
try to turn very carefully the basis of the lens
it worked on mine
Aug 19, 2008 | Ricoh GR Digital Camera
SAMSUNG DIGIMAX A 7
Sounds like a power issue. Make sure you use the recommended batteries. Also, some cameras have settings to where you need to change it in accordance to the type of batteries you are using. exp. alkaline, ni'mh, etc.
Dec 31, 2007 | Samsung Digimax S700 Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
