The buttons to turn the volume up and change the channels on my dab pure elan rv40 do not work. i can however turn the volume down and change channels down
  • 682 Answers
Make system microprossesor reset according to your model.
---try to make system reset by disconnection and connection.
if all above failed bring a spray lubricant contact cleaner from radio shack and apply spray in volume and channel buttons,
Posted on Aug 18, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do I correct a faulty volume on a pure evoke 2 DAB radio
Most likely the audio amplifier chip needs replacing.Other wise you could try spraying "CRC 2-26" into the volume control assembly.
Sep 28, 2014 | Radio Communications
Pure digital radio
Give it a firm thwack with the palm of your hand. I did that to mine and it started working again!
May 14, 2013 | Pure Digital Pure FMDAB Radio
MKS Steering Wheel Audio controls
My MKS had this exact problem earlier this year. I took it in and they ordered and replaced the buttons. It worked fine for about three months and now is starting to act up again. Have you gotten any definitive answers?
Apr 02, 2012 | 2009 Lincoln MKS
No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Nov 07, 2009 | Audio Players & Recorders
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Channels
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
Keeps changing channels/volume by itself
One or more of the front switches are likely leaky.  They are less than $3 apiece and I just change them all to save future problems.  You might be able to push all of the buttons on the front of the set a few times such as volume up and down and channel up and down and temporarly cure the problem but the switches will likely need to be changed.
Oct 16, 2007 | RCA F32650 32" TV
275 people viewed this question
 Grubhead
Grubhead
