What I do is take the carb off being careful not to break any gaskets, take it completely apart soak it in carb cleaner blow the parts dry and reassemble. replace the fuel tank filter, plug if fouled, and readjust the HI & LO speed jets. Works for me several times, leaving fuel in the tank and carb it gums up, run the carb dry before storing.
SOURCE: echo blower motor will not rev.full throttle--only about half
Check the insulator block and associated gaskets behind the carb. Sometimes the insulator block crack and reduce the amount of vacuum to the pulse diaphragm.
SOURCE: i have an echo gas powered leaf blower, model
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
SOURCE: Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Echo leaf blower will not start....leaks fuel from
sounds like u have a carb problem,ether theres debris stuck in needle valve needle is stuck open or the check valve diaphram is bad.take carb off on one side there is a plate with 4 screws remove then agasket and diaphram remove them some times they stick to carb so use a razor blade to go underneth diaphram all around from center youll see a metal see saw with a pin going through if u push on center it will lift needle valve on other side make sure it goes all the way down or remove by removing screw that holds pin in and blow out with air lightly may blow seat out after that on other side of carb take other plate off by center screw that diaphram has 2 little flaps check valves make sure they are limber and not wrinkled or bent if so u can get new ones at good mower shop or parts supply hope this helps
SOURCE: echo leaf blower..cranks fine, idles fine, will
Sounds like restricted exaust. Remove the muffler and start it, see if that fixes it. If yes clean remaining carbon from exaust port. And clean spark arestor screen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
