Question about Indesit Dishwashers
I'm considering an Indesit dif04uk dishwasher, and want to fit a decor panel to match kitchen. Can this be done, what is the available size on the door, without obstructing controls, and are these controls on the front or the top edge of the machine's door. Anything else I should consider?
    Champion:
  • 246 Answers
Have you looked at Appliance Art (http://www.applianceart.com)? they have several options that may be easier for you. I think there may be some options that will do exactly what you are looking to do at a fraction of the cost. Give it a try.
Posted on Feb 16, 2011
Didn't get any help from Indesit, but Screwfix Direct retail the machine and were very helpful and as a result got the order.
Posted on Aug 19, 2008
SOURCE:
Can it be fitted with a stainless steel door panel to match new kitchen?
Jerry,
You would have to look up and see if that particular model was even available in Stainless when it was manufactured. If it was, then you might be able to change it over. You will probably have to change the plastic housing that holds the control panel as well if you are wanting it to blend in with the rest of the kitchen, I assume it is white as well. Hope this helps!
Nov 23, 2015 | Dishwashers
I need to replace this model dishwasher but need new one to fit space and front cupboard panel .
from what i know unless you have an efficiency then most all are about the same size within 1/3inch
the bottom castors are adjustable.
you'll love the quietness of the new ones
May 04, 2015 | Dishwashers
Indesit model DG5400wg dishwasher can I fit new bottom door seal without removing the door bernice. If not can you tell me how. I'm fairly nifty wuth a screwdriver.
If you have a 90 degree screw driver you may be able to fit it enough to remove the 5-6 screws holding it in. may take some time but can be done with the right tool.
Dec 20, 2010 | Indesit 24 in. D63 Free-standing...
Without the decor panel on the dishwasher the door keeps springing back will this stop when we fit the decor panel
Normally there is a way to tighten the springs on the two sides of the doors. This is to compensate for the decor panel. If you don't have the decor panels you could ease the tension slightly by adjusting the spring nuts and that should stop the door springing back.
Will need to know the exact make and model of the dishwasher to work out the exact location of parts etc.
Oct 23, 2010 | Dishwashers
Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer panel.it takes about 15min.
Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Stainless panel for Kenmore 3631532 dishwasher?
I have two options for you to consider. One is to take your panel to any sheet metal fabricating shop and have them make a stainless steel version for you. The other is to get a spray can of stainless steel appliance paint and apply it. i have used the stainless steel paint on entire appliances with excellent results.
Jun 05, 2009 | Dishwashers
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
How to fix a panel to a semi-intergrated dishwasher
Contact the following address of G.E for their assistance http://www.geappliances.com/service_and_support/contact/ Good luck
May 05, 2006 | Hotpoint 24 in. HDA1000G Built-in...
Dishwashers Logo
162 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
