Question about Maytag Refrigerators
My refridgerator will not cool , the freezer works , it is a matag double french door style model.
    Problem Solver:
  • 15 Answers
Check the defrost system.. evaporator fan, heater, timer and defrost thermostat...
Posted on Aug 18, 2008
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Afi2538aeb will not cool refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Amana AFI2538AEB (256 cu ft) Bottom...
Refridgerator not cooling. Replaced defrost board. Snapping or popping noise heard underneath or behind.
Defrost coils are bad and burn out board...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Maytag Matag 25.6 Cu Ft Side By Side...
Refridgerator is warm freezer is cold
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 29, 2010 | Jenn-Air JFC2089HE French Door...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator not cooling
-check your thermostat setting at refrigerator it should be at cold. Same digital control they have separate settings.
- Check also the vents of your unit for obstruction.
Jan 13, 2008 | Refrigerators
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
47 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
