Question about Vtech VT5881 Cordless Phone
VTech VT5881 Does anyone know of a way to set the base unit to factory defaults?
Pay me and I'll tell ya
Posted on Aug 19, 2008
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
I bought a Vtech base set and would like to connect up my 3 CS6114 phones. I have phone service through Charter Cable.
the phones to be connected have to be the same model and make as the base station or it will not work
go google and type in --- user manual for ( make and model) cordless phone and there should be a pdf version download
Nov 08, 2015 | Uniden VTech CS6114 Cordless Phone Factory...
DVR-7318V Factory Default Settings
Look at the unit, you will be looking for a small hole in the unit. You might get lucky and it will say reset. If not the hole will be about the size of a paperclip end, and that's also the tool you will need. Push the button in the hole and HOLD it for a slow count of 30 seconds. Release it and let the unit go through it's startup . This should reset it back to factory default.
Feb 22, 2014 | Computers & Internet
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
Resetting answering machine message, lost instruction manual
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
Dec 10, 2009 | Doro DECT 850 Cordless Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
5808 drops call and starts searching for base
Got a wireless router? Change channels on the router off Ch6, the default channel and that may help your phone communication to the base station. I have had wireless phone customers lose their wifi when their phone rings, same frequency or intereference on that frequency.
Feb 13, 2008 | Vtech 5808 Cordless Expansion Handset
Resetting the router
There are two ways to reset the unit back to the factory default settings. Through the web-based interface: Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the System Tools tab and go to the Load Default Settings tab on the left. Step 3: Click on the Start button to proceed. This will now load the unit back to factory settings. Note: The Device IP Address will be reset to 192.168.0.1 after loading the default settings. Perform a hard reset: Step 1: Power the unit off by unplugging its power adapter (from the unit, not the wall). Step 2: Insert a paper clip into the reset pinhole. Press and hold the reset button with light pressure. Step 3: Power the device back on by plugging it in. Continue to hold the reset button. Step 4: Watch the lights on the front of the gateway. The status light and wireless light will power off. Once both lights are powered off release the reset button. Step 5: The unit will reboot and now will be reset to default settings.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Vtech VT5881 Cordless Phone Logo
51 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
