Question about Nikon Coolpix S1 Digital Camera
Nikon coolpix s1
Camera has been working just fine, last night I turned it on and it doesn't seem to be able to focus. A clicking sound comes from the camera and the image on the screen goes in and out of focus. On pressing the shutter button I get AF red dot and have even got a message saying something about the "initializing" lense not being able to focus. Does this mean that the focus mechanismo on the lense is jammed? I think it might... would very much appreciate any feedback.
  • 2,071 Answers
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 18, 2008
Nikon Coolpix S32 watreproof camera doesn't focusing properly
You have to know if the FOCUS is the issue or SHUTTER SPEED. In most cases with most CoolPix Cameras if the Image is not in focus (When you push shutter down HALFWAY) the Focus Rectangle will not be GREEN... If it RED it cannot focus. If every time you take a photo the focus area is red then it is not focusing. Small Coolpix cameras have difficulty focusing in low light.
Low light can make a hand held image look blurry because of hand shake. If the light is so low it wants to take a long exposure. This works with a tripod, but not with a hand held photo. With most of these small cameras you can take 1 second night photos with a tripod. They would look horrible handheld.
Typically on the Coolpix cameras you can set the FOCUS mode. It is usually shown with a FLOWER for MACRO... You get AF / FLOWER / MOUNTAIN / MANUAL (may not have this)
Plase make sure your FOCUS MODE is in AF AF is the ONLY Mode where the camera will focus CLOSE and FAR... Light is not your problem..... It seems it is your FOCUS MODE.
Jan 21, 2017 | Nikon Coolpix S32 White 13.2 Megapixel...
How come when I take pictures they are coming out blurry? Even when the subject is completely still and I let the camera focus before I click it still comes out blurry? Do I need to change a setting on my...
This kind of issue is usually caused by the night vision mode of the camera being switched on.
In some cases, the cause may be more than just the night vision being turned on but just to be sure, it is advised that you turn of any function that has to do with the night vision feature.
These features may range from the night vision mode itself and then to the night vision lighting.
Hope this was helpful?
Feb 22, 2011 | Nikon Coolpix L110 Digital Camera
I have nikon coolpix s1 but while i am connecting it by data cable or by card reader with my laptop (Dell inspiron 1525 vista basic enabled ) it's just showing Nikon file of 512 KB only but i have clicked...
Sounds like you've been viewing these pics occasionally on the computer but forgetting to use the "safely remove hardware" function when you're finished. This will sometimes corrupt the files and they will disappear on some devices.
Jul 12, 2010 | Nikon Coolpix S1 Digital Camera
Nikon coolpix s630, lens error, blurry, ticking sound
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2010 | Nikon COOLPIX S630 Digital Camera
My nikon coolpix s210 has a lens error. I turn it on and the lens comes out. It make a err sound and seems like it cant focus. it goes back in and says lens error until i turn it off. I need it. I cant...
if its brand new, then you can replace the lens array for free of service charges in the case you have all the documents. it generally happens if you have dropped the camera.
Jul 09, 2009 | Nikon Coolpix S210 Digital Camera
Does anyone know how to turn OFF the auto focus on the Nikon Coolpix 4600??
Hello, After doing some research on the NIkon Coolpix 4600, it seems the camera is constantly doing the autofocus thing. IOW - it can't be turned off. Hope this helps.
Dec 03, 2008 | Nikon Coolpix 4600 Digital Camera
Broken screen
try to find a person to fix it
Mar 23, 2008 | Nikon Coolpix S1 Digital Camera
Camera "dead"
Did you try taking the batteries out? If not, try that and then put them back in again. This might reset the camera back to normal. Also, try turning the dial. Make sure it is at the camera setting, then try shutting it off. Further, move the dial to Set-up, and scroll down to the Reset all setting, press the right arrow and answer "Reset".
Sep 18, 2006 | Nikon Coolpix 5600 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
96 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
