Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Engine is poping (backfiring) when I let up throttle.
When riding my 1999 fatboy and I let up the throttle you hear a loud backfiring noise through the exhaust pipes, If I pull the clutch in it stops! It seems to be getting worse and last night it stalled on me twice at an intersection. Any help would be greatly appreciated. Thanx
  • 216 Answers
Most common cause of backfiring would be a vacuum leak....most common areas that develope leaks would be the manifold seals. I'd check there. To troubleshoot...warm up your engine and with it idling...spray some starter fluid on it and see if the engine speeds up. If it does... theres u're problem. While u're lookin around, check all your hoses for good connections and good rubber. If that doesnt do it...check your pipes for tight connection
Posted on Aug 18, 2008
2001 dodge grand caravan wants to start it goes through the starting procedures then chokes out
could be a timing issue and the loud noise is a backfire through the exhaust manifold
Feb 16, 2015 | 2001 Dodge Grand Caravan
No power when give it gas.
believe carb adjustment bad & carb needs to be rejetted to exhaust, believe you need to add a higher flow gas valve & possibly new plugs & wires
Apr 21, 2014 | 2000 Harley Davidson FLSTF Fat boy
99 fatboy has no power
Hi Anonymous, you have all the classic symptoms of retarded timing, bad intake seals, and incorrect clutch adjustment, or wrong type of primary oil, or contaminated and or warped clutch plates. Good luck
Apr 19, 2014 | 2005 Harley Davidson FXSTI Softail...
Backfiring on triumph st sprint 1999
After-market exhaust system or stock?
A lot of after-market mufflers don't cover up a backfire pop on over-run in the way that the stock system does. Look at The Marble Mod on GIXXER forums for ways to doctor the bike's emissions system to stop the popping.
Another cause of an over-run backfire may be a slight leak where the header pipes emerge from the cylinder head. Check the bolts are tight. Consider new copper washers.
Nov 14, 2013 | 1999 Galfer-2001 Triumph Sprint ST 955...
My car wont accelerate and there is a loud popping noise on the passenger side when it tries to go
Dodge stratus V6 ?
You should have a check engine light on in your dash.
You will need to have someone plug in a OBD II reader to retrieve the code.
I believe the loud poping noise you hear is the engine backfiring, from either a fuel or electrical problem.
Please let me know what you find.
Feb 07, 2010 | 2001 Dodge Stratus
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
I was driving the car, then it made a loud noise the whole motor was shaking. then would not turn on
SOUND LIKE TIMING CHAIN JUMP TIME BECAUSE IT WORN HAD A LOT OF SLACK CAUSING IT TO SLIP TIME.THE LOUD NOISE YOU HEARD IS THE ENGINE BACKFIRE.
Oct 25, 2009 | 1999 Oldsmobile Alero
1998 bmw 528i severe misfire
If you've never replaced the timing belt or chain,That would be my first thing I'd check is the Timing belt or chai, just aline the timing marks on crankshaft and then look at the position on the distributor to see if it's pointed in the #1 firing position .
May 02, 2009 | 2008 BMW 528i Sedan
Lands Phones Logo
656 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
