Question about HP Scanjet 5590 Flatbed Scanner
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Sounds strange but the scans that get feed through the ADF show some text through the paper on the reverse side almost like the paper is transparent but on the flat bed the scan is perfect with no image showing thorough, Can you help?
kind regards
Paul
  • 490 Answers
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Posted on Aug 20, 2008
I get a red line down one side of the page when scanning using the adf on a HP 5590 scanner
My guess is the ADF has picked up some dirt. Check the path very carefully.
Nov 04, 2011 | HP Scanjet 5590 Flatbed Scanner
When scanning with the ADF all I get is a white page. I cannot find a solution. This is the second scanner I have had as I sent the first one back with the same problem. Maybe I am doing something wrong.
You could be feeding the paper upside down.
Try turning the sheets over and re-scan.
The paper travels into the scanner from the top and then onto the glass. This means the paper should start out with printing face up.
Dec 18, 2009 | HP 5590 ScanJet Flatbed Scanner
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
Install feed rollers in ADF of HP scanjet 5590
You can get a service manual at this website address (HP website):
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Scanjet+Scanner&qry=instruction+manual&submit.x=7&submit.y=4&ctry=emea_africa&lc=en&dlc=en&mode=fb&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
Feb 06, 2009 | HP 5590 ScanJet Flatbed Scanner
ADF
1- reinstall drivers
2- Use the WIA driver for Windows OpSys
3- Pay close attention to options in dialog box. Select ADF or Document Feeder as an option
4- Depending on the OCR application [personally I prefer PaperPort] the imaging process can be very eaasy or somewhat difficult
Jun 02, 2008 | HP Scanjet 5590 Flatbed Scanner
HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
Apr 16, 2008 | HP 5590 ScanJet Flatbed Scanner
HP ScanJet 5590 automatic feeder not working
Have you tried scanning in the flat bed mode? Does it scan okay? If the image is good, then there is no problem with scan module. Check your page settings. If the page size selected for scanning is smaller than actual size, there can be some peoblems. Try and scan with max size. Check if the sensors are dust/paper free. A small piece of paper (The small round discarded piece from Computer stationery) in the paper sensor can create trouble.
S. Mohan
Feb 21, 2008 | HP Scanjet 5590 Flatbed Scanner
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
HP Scanjet 5590 Flatbed Scanner Logo
184 people viewed this question
Seeker5211
Seeker5211
