Question about HP Pavilion F1903 19" LCD Monitor
On switch doesn't always work!
Hi, I have a 19" flat screen HP monitor with the "soft" style on/off swtich. The switch is increasling difficult to operate (my wife and kids couldn't switch it on this morning!). Any tips?
  • 2 more comments
  • goconno2 Aug 19, 2008
    Hey Benimur, thanks for help; I tried last night but not sure how to get case open (didn't want to damage it!). I removed the four short screws in the corners but this didn't allow removal of front panel. Is it simply clipped on? do I just need to un-clip it or do I need to remove the four fixings in the centre of the back panel (wal mounts I guess)? Or something else?
    Thanks again,
    Gary
  • goconno2 Sep 15, 2008
    Hey Benimur, thanks for help, didn't manage to get around to getting cover off, but swtich did seem to improve in performance; until last night...... I couldn;t get the thing to switch on. So, I managed to get the cover off but........there isn;t a swtich as such, it's just a "ribbon" type strip that seems to intergrated into the front cover. I didn't want to pull it put as I'm worried I may damage it or not be able to get it back in. I don't know what to do now?
    Ok, I can see through the soft button to the trace on the ribbon, does this mean the carbon contact has worn away? Is there anything I can do with it?
  • goconno2 Sep 16, 2008
    Fixed it with a bit of silver foil under the outer soft switch. This keeps the contact open when not depressed and makes it when pressed. thanks for your help.
    Brigadier General:
  • 6,966 Answers
Assuming no other fault other than the switch itself, it would require that the unit be opened and the switched exposed. Underneath the button would be the actual switch. it is possible that:
  • cold solder - would require re-application of heat through a soldering iron;
  • dirty contacts - initially try electronic contact cleaner or if still a no go, then replacement;
Often the repair is rather quick and easy, what might be more demanding would be opening the case/paneling to expose the switch. Should you be uncomfortable going through this route, then perhaps your best bet would be to seek the services of a qualified professional. In considering a DIY (do-it-yourself), familiarity with electronic components and circuitry is a necessity.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Aug 19, 2008
    Hi again,
    Appreciate the postback.
    To your concern, very often the two halves are held in place by snap on locks. You would need a spatula like tool to force insert between the two halves and slowly move it along. It will reach a point where it will be stopped by the interlocks. You would need a small flat bladed screw driver to unsnap these locks. Another tool would be needed to keep the area that you have separated apart while going through again with the spatula tool on the other sections.
    It is not uncommon to have scratches. There are even instances that the locks are sheared/snapped off. The secret is to do it slowly.
  • Louie  Role
    Louie Role Sep 15, 2008
    The switch is a soft switch, something similar to the keypad of cellphones where the switch contacts are the trace themselves on the ribbon. The actual contact is provided by a carbon looking part on the internal end of the push button.
  • Louie  Role
    possibly as you posted but another possibility is that what it is switching is the culprit. often designs such as this relies on a switching component, the manual switch is actually triggering another component that does the actual switching.
    try first if you can clean the soft switch, again just like in cellphones, the membrane/carbon could be lifted away from the trace. doing so would allow you access to both and therefore clean.
6ya staff
SOURCE:
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
Monitor went out and only displays a black screen. The power button indicates that the power is on but no picture. The model is an HP f1905 19 inch flat screen monitor.
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
Mar 31, 2011 | HP f1905 19" Flat Panel LCD Monitor
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
How to open the HP 19 inch flat screen monitor
You need to remove the stand first, and then using small flat screw driver to release the four tabs at the bottom edge of the monitor.
I myself never have to replace the power switch on these series yet.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Screen always flicering
If the screen is flickering then I would assume its a dry solder on the inverter board or the LCD panel is about to die. Are you skilled in electronics?
Feb 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I have a problem with hp crt monitor can't display caracter but only light like rainbow on the screen can yaou give me solution please thanks
Hi...there,
Well, it is time to upgrade to a LCD flat screen monitor... The one you got it's busted.... You get buy one 19" LCD monitor less than $200...
Dec 01, 2008 | SAMTRON 55V 15" CRT Monitor
HP 19 IN. LCD MONITOR
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
HP Monitor blanking out on full screen mode
It may be worth going to the game makers web site and see if there are any patches regarding your make of your graphics card. It may also be the fact that the game resolution does not match the screen resolution, try changing it in the game settings if it's possible for you to do so, as the monitor seems to be struggling with the change of resolution as you start up the game.
Jul 30, 2007 | HP L1940T 19" LCD Monitor
HP Pavilion F1903 19" LCD Monitor Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
