Paper not loading instruction no.2 solid green light not on
  • 1 more comment
  • Anonymous Jan 04, 2009
    when the paper is inserted in the tray, the printer rollers make not attemp to grab the paper. Nothing happens!
  • Anonymous Jan 23, 2009
    rollers not grabbing the paper
  • Anonymous Feb 26, 2009
    Paper not loading at all. Only the sound of rollers in the tray but nothing moves above the paper tray. Printer doesn't recognize tray is loaded.
    Problem Solver:
  • 12 Answers
Turn off and then turn on back the printer.
Try to print at test page, but do not put paper in the printer, till you asked to do so by the application.
Put the paper and see if the rollers are at least attempting to grasp the paper. If they are not, try to push the "load paper" button that is located on your printer.
Let me know,
Angela
Posted on Aug 29, 2008
    Problem Solver:
  • 12 Answers
Is that mean the printer cant be power on?
Posted on Aug 26, 2008
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Tip
Printer : Checking the printer
Check the lights on the printer
Power in solid green - printer is in ready mode, else:
  • disconnect and try another power source or power-adapter.
Paper Feed in solid red - no paper:
  • make sure paper is of the correct type and dimension. re-seat the paper.
Error in solid or flashing - hardware problem:
  • turn off the printer.
  • open and access the DIP switches, make note of the current settings, then set it all to zero.
  • remove the Connect-It module at the back and re-install it.
To test the printer do the following:
1. Disconnect the printer from the computer.
2. Turn the printer off. Make sure that there is paper and properly loaded.
3. Press and hold the Paper Feed button while turning the printer back on.
4. A self-test print-out that contains information such as firmware version and settings depending on the detected connection type.
on Oct 14, 2008 | Epson TM-T88III Thermal Printer
Printer feeder is not picking up the paper to print. Goes thru the motion like it is going to print but does not oick up the paper in the paper tray????
Please reset your printer ... your printer ink absorber is almost full. Follow the instruction... 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal. thanks....
Aug 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
When is my battery charged, is it when the light flashes or when the light is solid green as i have lost the instructions
When you snap the Leapster into the charger, the green light should come on (solid green). When it has finished charging, the light should go out. I don't know why it would flash green aside from maybe a bad connection.
Hope this helps!
Mar 01, 2011 | LeapFrog ® Leapster®2 Recharging Station
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have problem with Dell 1720dn Printer its not working one green light is on and another Amber light solid on paper sighn can you help me
According to the manual the light combination meas the following:
Load <input source> <type> <size>Load the specified paper input tray with the designated paper type and size.
This info can be found here at this dell website:
https://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e772.html#operator-panel-lights-chapter
Good Luck!
Rich Lilja
Jan 21, 2009 | Dell 1720dn Laser Printer
PRINTER WILL NOT PRINT
1. make sure there are no error lights in the printer & you have a solid green power light
2. if you have a green power light, try reinstalling the driver
3. if the printer has error lights, check inks or paper obstructions
Jul 30, 2008 | Lexmark Office Equipment & Supplies
Can't print - paper light is on
turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
Jul 25, 2007 | Brother HL-5250dnt Laser Printer
350 people viewed this question
jasbo
jasbo
