Question about Intel Motherboard
HI - benimur
HI
All fans are working ... and I changed my smps, i remove the HDD connection and observe then also it restart
    Brigadier General:
  • 6,966 Answers
  • fans, OK;
  • PSU, new;
  • HDD, disconnected;
  • ad no part/component heating up (barely touchable).
that leaves us only three possibilities:
  • motherboard (most likely);
  • memory (likely);
  • CPU (least likely)
Posted on Aug 18, 2008
I have a hp elitebook 2530p laptop problem is the hdd is not detect so i change the hdd connector for example - to + +to - problem create display is gone but laptop is on so what we do plz send the...
Hi Friends,
First of all HDD inducted connection, No any - or + option. simple hdd and cable same option given. If you are - to +, or + to - connection may be you HDD damage. So you check it you HDD wall conduction or not. If wall status then you change HDD cable and port and open bios and see you HDD show or not. change you SMPS power connector used different port connector. Nest problem is Display not then you check SMPS proper power comming, No any beep sound in PC, RAM, etc. Finally Change HDD and then check it.
Thanks..
Aug 30, 2013 | HP EliteBook 2530p Notebook
My Smps is not working properly. My engineer claims that its because i used 2 hdd nd 1 dvd drive. I should not use 2 hdd on my pc. He is also telling me to replace me smps. Is he right ? Can using 2hdd and...
Hi, the answer is NO. you do have issues on the power supply box. you can test it alone safely by plugging it on the ac, and short the green and any black wire on the 20/24 pin connector using a piece of striped wire. if the exhaust fan spins continuously its ok, else its bad.
Jun 20, 2013 | Computers & Internet
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
One of my fans has started making noise, how much time do i have to replace it? Am I right in thinking that it making noise that it needs to be replaced?
fan noises are usually caused by worn out fans. but can be also caused by IDE/power cables hitting the fan blades. you will have to open up the computer to see where the noise comes from.
if it is a faulty fan, replace it sooner than later as it will get louder and louder. then stop making noise all together when the fan fails.
Dec 09, 2009 | Dell OptiPlex GX270 PC Desktop
Switched it off last night. this morning no power. won't switch on. not lead have tested. thanks
Verify whether the SMPS fan is working or not, working of this fan indicates that power output +12V is OK, if not you need to check the SMPS, probable reason SMPS fuse blown.
If you observe SMPS fan rotates for few seconds and then stops, this indicates minor repair is required, let me know the symptoms.
Oct 09, 2009 | Acer Power S290-EC3600P PC Desktop
Hi - benimur
Pls check:
  • if CPU heatsink fan turning;
  • if heatsink is flat on CPU and tight;
  • if PSU exhaust fan turning;
  • if Video Card heatsink fan turning;
  • with a voltmeter, pls check consistency of the yellow and red wires (+12 and +5);
  • pls inspect capacitors near the CPU, none should be blistered, bulging are leaking;
  • remove the HDD connection and observe it will restart, if no, then probably a driver/software issue.
Aug 18, 2008 | Intel Motherboard
There is a problem in starting the system
check the battery and check the hdd belt also and also check the smps
Jan 17, 2008 | ASUS P5PE-VM Motherboard
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
