Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
ON/OFF & Time saver Button keeps flashing
Hi, just out of the blue the ON/OFF button and Time saver button started to flash rapidly. I disconnected and reconnected the mains, the ON/OFF button lights up by itself for few seconds then it starts to flash rapidly with the time saver button. I have tried to start a cycle of washing or drying to get out of the loop, it did not help. Any ideas?
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Posted on Sep 01, 2008
I have a 2008 F350 6.4 diesel with no crank no start pats light flashing rapidly and airbag light flashing
you must disconnect the battery for 5 minutes then when you reconnect the cables press the alarm deactivate button on your remote I believe your car will start and when you see the pats light rapidly flashing the cars in theft mode and will not start
Nov 04, 2016 | 2008 Ford F-350
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
Driver's visor 3 buttons what for and how do i use it infiniti i30
Those buttons are for you to be able to program your garage door opener so that you don't need to have to original clipped to your visor all the time. The procedure is this: 1) put the key in ignition in postition 2 (car not running)
2) hold down both homelink buttons on the outsides of the homelink transmitter (to reset any existing codes) you might have to do it for 20-30 seconds. Red light on homelink will flash rapidly then let go.
 3) Now, with the garage remote in one hand and hold the button on the homelink you want to program (keep holding homelink until it pulses, not a rapid flash, takes about 20 sec.) While it is pulsing, hold down the garage opener as close to the homeling button as possible while depressing door opener button also.
Shortly after doing this you will see the homelink start to flash rapidly (this means it is learning the code).
-  let go of both buttons once it is flashing rapidly and
4) go to motor of door opener and hit the learn button (a light should turn on)
5)return to the car a press the homelink button you programmed once, twice, or maybe up to three times until you see garage door open/close.
You may need to have someone help you with this procedure.
Apr 15, 2009 | Infiniti I35 Cars & Trucks
The detector (whistler xtr 695) will randomly power off
Hi-I have one also-great detector-probably the most complicated one I've ever had! Possibly you are in battery saver mode which will turn off 1,3,6 hour increments! About the 14th time on menu you will see B SVR ON at that time push the Q button to inactivate the battery saver mode-should show B SVR OFF. John
Mar 20, 2009 | Whistler Vehicle Parts & Accessories
The on/off button and saver time buttoon are flashing
Yes I have the same problem but the Drying High Heat is also flashing
Feb 22, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
832 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
