Question about Epson Aculaser C1100 Printer
C1100 B Open error
I have the error that says the B cover is open even though it is not!! Is there a solution to this VERY annoying problem especially as i have recently bought new cartridges for the said beast?
    Brigadier General:
  • 6,966 Answers
Often, this would just be the sensor falsely thinking that the cover B is still open. You could try checking if the cover is slightly misaligned hence the tab is not triggering the senor/switch. Or try opening and closing and making sure that you hear/feel the latching of the switch.
Better yet, perhaps the parts diagram may be of better help. You would probably be interested likewise in the service manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
Error e527 have manually removed all cartridges and replaced them and the PCU but the error code persists
Error E527: home position sensor error
Solution:
  1. open the left cover
  2. remove the home position sensor
  3. clean it ( remove the toner)
the home position sensor is shown at this picture: mabroukmedal_32.jpg
Dec 09, 2010 | Epson Aculaser C1100 Printer
Epson c1100 B open
hi
the cover B is not closed correctly: open cover B and colse it again
covre B is Nuber 1 at the picture below
Oct 27, 2010 | Epson Aculaser C1100 Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Dec 20, 2008 | Epson Aculaser C1100 Printer
Epsom C1100
cover "B" should be on the back of the printer. when you open the main back door at the bottom there is a little flap that will fall down, this is a sliht design flaw as you have to make sure that this is in an upright position before closing the main back door. from past experience its usualy hit and miss at getting it to work unfortunatly
hope this hepls
Pete
Sep 28, 2008 | Epson Aculaser C1100 Printer
Epson c1100
Look for the switch on the rear cover above the fuser. It is often this switch this gets bent out of the way and causes the error.
Get a service manual HERE if you need to take the switch out or see which ones are interconnected
Jun 28, 2008 | Epson Aculaser C1100 Printer
B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Feb 04, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
673 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
