Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
Warning tone? On several occasions and when not in use, the Cuisinart Classic Toaster Oven Broiler has emitted a high-pitched tone that is continuous and only stops when I unplug the unit. Is the unit defective?
  • tzaremba
    tzaremba Jan 28, 2014
    Mine does the same thing and turning function off does not fix it.
Have you tried turning the function button to off? This has worked for mine.
Posted on Sep 15, 2008
SOURCE:
We have a new cuisinart classic toaster oven broiler. It burns everything I try to bake . Never had this problem with others .
Hello, Joy -
Since your toaster oven broiler is new, after you check the warranty information in the user manual, contact the Cuisinart company and find out what you need to do to obtain a new replacement.
Note: You may need to provide a copy of the sales receipt for the toaster oven broiler in order to obtain a replacement.
See the information from Cuisinart here (Product Inquiries):
https://www.cuisinart.com/support#us_tab
Best wishes.
Mar 19, 2018 | Cuisinart Toaster Ovens
Parts I need a new Broiler Rack (P/N 21432) for Toastmaster toaster oven, Model 337. Mine doesn't have the convection oven as it is an older model.
My manual has 1(800)947-3744 Mon-Fri 8:00 am to 5:30 pm CST I have purchased a broiler pan from calling them in the past; now my unit just died yesterday so need to find another.
Jul 01, 2014 | Toastmaster 337 Toaster Oven with...
User Manual Oster-Toaster-Oven-Broiler-6233
If manufacturer site is of no help, check here, they have the Oster 6233 manual for download.
Aug 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
How do I clean the drip tray and broiler pan?
The drip tray pulls out the back of the oven. It can be soaked in hot soapy water.
Jun 19, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Cuisinart: toaster part of toaser broiler oven does not work
Definitely a defect - return to store if possible, or call Cuisinart - it has a 3-year warranty.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart TOB30BW Toaster Oven with...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
600 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
drbobb
Level 1 Expert
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
