Question about Samsung Audio Players & Recorders
We have purchased the Samsung surround sound with blu-ray player, which is connected to our Samsung 46” LCD 6 Series TV. When watching television through the blu-ray surround sound, every ten minutes or so there is a break in the sound for about two seconds, this happens continually, but only when watching television, not watching DVDs etc….. We do have the two systems connected with an Optical Cable. Can you please explain what would be causing this and how it can be rectified ASAP……?
  • 2,071 Answers
That's only in television signal thats catch a radio frequency signal but can't occur when playing DVD,maybe near to your place there someone using a radio com...
hope this may help;
DON'T FORGET TO RATE;
Posted on Aug 21, 2008
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
I have a Samsung 46''B6000 tv hooked up to a samsung Blu ray player B-1590 via HDMI cable. During the course of watching a BR disc, the volume had to be increased all the way up to 100 (max), to be able to...
This happens on our samsung too with some dvd's.
It is not the tv's fault (in my case) but have to turn the volume button on the dvd remote up full first then adjust from the tv remote as required.
Oct 19, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Jan 30, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Pink and green lines while watching a movie
if this is only happening on your dvd player, then change the type of cable used to link the tv with the dvd player, if that does not fix it then try another dvd player to make sure it's not the player itself
Dec 25, 2008 | Samsung LN40A650A LCD TV
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Advice on the best way to connect
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
Jun 29, 2008 | Samsung Audio Players & Recorders
Brightness keeps shifting on Samsung 46" 7 Series 750
I just purchased Samsung series 4 LCD TV yesterday. I had the same problem since my salesman was a kind of stupid. He set the 'Power save mode' to automatic. After fiddle with my TV for a while, I found the solution.
Just change the 'Power save mode' to off, low, normal or high. My LCD TV stopped shifting its brightness.
Jun 23, 2008 | Televison & Video
115 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
