Blown crossover in a Peavey Pro-Sub 15" speaker cab. Can this be repaired? If not, where can I get a new crossover? I went to Peavey's web site and this particular crossover isn't on there.
  • 4,234 Answers
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Posted on Aug 18, 2008
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Horns wont play in peavey 215
broken crossover or bad diaphram or wire off in the high circuit.
Mar 13, 2014 | Peavey PV-215 Dual 15 2-Way Speaker...
Well I have a Peavey pv10 mixer. I'm going out of the outputs on the mixer to my amp. Then the outputs on the amp go's to my main speakers. I'm not sure where to add the powered sub. If you need more info...
The easiest thing to do is add an outboard crossover; something like a Rane AC 22S. Set the mode for stereo 2-way & mono sub out. L & R mains out from the mixer to the crossover, mono sub out to the sub and high out's to the full-range speakers.
Oct 12, 2013 | Peavey PV10 USB Mixer
Was gigging with peavey 112xt subs and hisys 6 rx sats, one side went very low and ive isolated the problem to one of the subs, i was using dynachord 1000 powermate and driving it pretty hard, have i blown...
To pjstokes.I have exactly the same set up as you and have experienced the same problem. So far I have Changed The Bulbs inside the tops and also replaced the thermal fuses on the soundguard circuits (which are inside the 6XT tops) but still have the problem. Only when the cabs are driven hard do they stop working, no problems at low volume. Peavey don't have a solution. I think maybe some of the other components have blown but I don't know which ones. If anyone knows a solution please post it here.
May 30, 2010 | Peavey TLS115X Speaker
I have bought a Behringer Europower 6000 mixer amp. I have 2 Peavey Pro 15 cabs and a subwoofer for each side. They are all rated at 4ohms. The guy in the shop told me to put the amp into the subs then...
No !!!!... you don't want to go below 4 ohms. Paralleling each sub and the Pro 15 would be like 2 ohms...
With those cabinets, either have a second amp driving the subs from the mono or main 1/4 inch jacks out of the mixer or the other thing is a kludge to series each PAIR, that is series the Pro15's to form 8 ohms and the subs to get 8 ohms and run the 6000 as a split between the A and B. The pan controls would not be useful this way at all.
I would recommend using a seperate amp for the subs.
Whoever that shop is wants you to burn up that unit so they can repair... don't do it... BE VERY careful to ensure speaker leads are solid as that amp can destroy itself if the speaker leads short or momentaarily break... I repair these amps... I know...
May 16, 2010 | Peavey PRO-12 (00497070) Main / Stereo...
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
I have one Peavey SP5 that suddenyl lost the Woofer end. Horn still spits out but absolutly NOTHING at all from the Bottom 13". I swapped out fuses adn same problem, I switched outputs on the amp, same...
If you have a pair, swap the woofers. If the other one works in the cabinet, then it's definitely the speaker. If it doesn't, then you've likely got a problem with the crossover inside the unit. I believe you can get a replacement crossover from Peavey. If it's the speaker, google speaker re-coning in your area, as it's cheaper to re-cone the speaker than replace it.
Jun 07, 2009 | Peavey CH1 Speaker
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
No low end on JBL EON G2
please use a different connectors and try if it works
Dec 15, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
319 people viewed this question
 Grubhead
Grubhead
