Question about HP Office Equipment & Supplies
Installing a new HPC8180 printer. followed instructions through setting langauge and country etc until screen "Initialization begining". Screen notes "one time ink system initialization beginning. Do not turn printer off or disconnect power during process. Press OK to continue". I have pressed OK, and it has sat doing nothing obvious for the last 50 minutes. Is this normal? What do I do?
  • ian greig Aug 21, 2008
    The online HP guide has a different sequence for starting up the printer than those that came with the printer: the on line guide worked. Additionally, when running the software disk, it would not complete the install from the normal 'run' command, but did so successfully when the install was sarted from the 'Add Printer' command! It makes no sense to me, but hey, it now all works.
    Genius:
  • 2,785 Answers
Plz try by reinstall the software for the printers
Posted on Aug 18, 2008
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
How to clear back to factory setting
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Jul 30, 2011 | HP LaserJet 1300 Printer
I have Cannon MF5700 printer. It is frozen and it says "DOWNLOAD CONNECTED" Help
Your printer's firmware somehow got wiped or messed up so that the printer is having trouble doing its initialization boot up. You need to re-flash the ROM on your machine, which is a to say, you need to install new firmware. You can get it from the Canon website. Just find your product in their product support page, go to the software and drivers section, and find the firmware. Download the problem, run it and follow the directions. Make sure the printer is hooked up "showing download connection" and follow the prompts until it updates the firmware and you are back in business!
Apr 03, 2011 | Canon imageCLASS MF5750 All-In-One Laser...
HPC8180 Did not follow intitial instructions and now have ink system failure. Hp unable to help sent me brand new ink cartridges, I tried to reset with no success. Any help?
Follow the instructions on this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/ to prime ink through the lines and hopefully clear the error. I don't know why HP sent you new ink cartridges when it should be obvious to them that the cartridges are not the problem.
Nov 25, 2009 | HP Photosmart C8180 InkJet Printer
Message states: the following ink cartridges cannot be used after device intialization, and must be replaced
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK.
5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button.
7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds.
11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
Thanks,
Fame..
Oct 23, 2009 | HP Photosmart C6280 Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
