Question about Intel Motherboard
Hi - benimur
Again having the same problem .... now system will restart every 5 min.
    Brigadier General:
  • 6,966 Answers
Pls check:
  • if CPU heatsink fan turning;
  • if heatsink is flat on CPU and tight;
  • if PSU exhaust fan turning;
  • if Video Card heatsink fan turning;
  • with a voltmeter, pls check consistency of the yellow and red wires (+12 and +5);
  • pls inspect capacitors near the CPU, none should be blistered, bulging are leaking;
  • remove the HDD connection and observe it will restart, if no, then probably a driver/software issue.
Posted on Aug 18, 2008
Xlt 1200 2005 jetski runs well for about 5 mins then stops , it wont start for about another 5 mins.
Not sure but what work i have done on these machines always seem to involve the exhaust system and the water it contains
Dec 18, 2011 | Yamaha Boating
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
I have a 1994 Mercedes C220 When first started the A/c works fine for about 5 min. After 5 min the A/C system still blows but not cold. when the A/C is working it only blows on the 2 outside vent. If car...
i think its something to do with the computer controlling teh AC it does have one behind the centre console but what is wrong and how to do i have no idea to be honest ,this computer is controling the flaps on the heater unit that i do know as its a similar system to my jag ,best advice i can give is to back car to merc dealer and hope your credit card can stand the knock ,or trade it in for a nice small new car with a diesel engine
Aug 22, 2011 | Mercedes-Benz C230 Cars & Trucks
Mge pulsar ex10 stop after 5 min with 60W charge,after I changed the pack of 3 bateries with one new.if I switch off and on works again 5 min. all 3 bateries are good,Vcharge=13,6v Vin use=12,3v thanks
Some economics UPS have a functin called "Green Function". A timer disconnect the load after 5 min to prevent damages on internal circuit.
You can confirm this:
- battery remain to good level charge
- UPS restart for other 5 min if you press On button
See manual if you can disable this features.
Sep 28, 2009 | APC Computers & Internet
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Forwarded problem
Hi smartsolve,
Appreciate the direct "Ask Me" and much more calling my attention to this concern. I have to admit that I missed seeing this and your "Ask Me" saved me from an embarrassing situation.
With your kind indulgence, I would bring this action of yours to the attention of the community in general through the Lounge that others may emulate your "team spirit". Again Thanks.
Benimur
Sep 27, 2008 | Computers & Internet
Hi Benimur
Appreciate the direct "Ask Me".
To your concern, initially pls try:
  • remove the memory sticks;
  • clean both slots with a clean dry toothbrush/paintbrush. You could also use a can of compressed air or an electronic contact cleaner spray;
  • clean the little gold pins of the memory using a pencil eraser.
  • If the above is not sufficient to address the issue, pls try resetting your CMOS/BIOS to default condition.
This is of course assuming that there is no hardware fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Intel Motherboard
Engine stops but can start again straight away
Other than those described (and that you have checked), Have you checked the "Idle Control/Stabilization Valve"? It is also sometimes called the "Idle Air Control Valve".
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Jul 06, 2008 | 1995 Volkswagen Golf
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
Sytem Hangs!
Looks like a bad Memory dimm, try replacing it.
Oct 03, 2007 | Computers & Internet
Intel Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
