Hi, I've got a Sanyo hifi on which the motorised volume knob no longer works. It is not a fault with the remote control as I have tested this. Suggestions welcome! -Jamie
  • 2,071 Answers
Just clean it with alcohol and reworks solder joint so it will function normally..
hope this may help;
Posted on Aug 21, 2008
Motorized volume control has to be serviced. Either the drive circuit or the motor/linage is defective
Posted on Aug 19, 2008
I have a kenwood vr506 amp . the remote no longer works.i have bought a one for all universal remote and need the code for the kenwood amp.
setup codes for cd players - HiFi Remote
www.hifi-remote.com/hag/setup_codes.htm
Sep 15, 1999 - If you are unsure whether your universal remote uses 3 digit or 4 digit ... SETUP CODES FOR AMPLIFIERS ... 0078 JVC 0331 Kenwood 0356 Linn 0269 Luxman 0165 Magnavox 0269 ... GE 0240 LiteTouch 0084 Lutron 0318, 0597 One For All 0167 .... 0048 may require TV code 0093 for volume and mute.
vcr set up codes - HiFi Remote
Feb 16, 2015 | One For All Televison & Video
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
Volume / audio control knob
Hi, did you ever get this fixed, if so for how much and where. I have the same problem with my knob, it does not control the volume level but you can still access the other functions that require you to push the knob, like a button. My remote battery is dead so I have not being able to test it, it's just the knob no longer controls the volume.
Dec 01, 2011 | Audiovox MP6312I
Hi, I have a problem with my Thomson HiFi CS97, actually I have lost my remote control, is it possible to order another one as a replacement? Thank you Lenka Kralikova
When I put in your model number and manufacturer I get this Sanyo remote. Does this look like your original remote?
http://www.replacementremotes.com/SANYO/Buy-REM9625-6450175251-Remote-Control.html
Feb 03, 2011 | Thomson Televison & Video
Sound volume knob does't respond
Chances are that it's a digital volume control.
The fact that it turns down again means it's probably fixable.
Open it up (switch it off first), and fetch a soldering iron. Look around for wires that go from the volume control and see if any are loose connections/broken wires etc etc. Solder these again, and it should work.
If you don't fancy this, take it to a hifi shop and they'll fix it for you (there'll probably be a fee involved)
Jan 13, 2010 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
Need four digit code for sanyo tv
The Sanyo TV codes are - 0154 or 0159. Try one and if it doesn't work use the other.
You can find remote codes here - http://www.hifi-remote.com/ofa/codes-tv....
Jun 19, 2009 | One For All URC-3300 Remote Control
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
62 people viewed this question
 Grubhead
Grubhead
