Question about Microsoft Office Access 2003 (077-02871) for PC
How to use passwd character in a table in ms-access 2003
I am doing a database project in vb.6.0 with back end ms access i want to keep my data in a table in the form of passwd character how can i do that
  • 40 Answers
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Posted on Aug 19, 2008
How to fix error in database: microsoft office access has detected corruption in this file
System restore will not restore any data files, only system files.
Databases normally need periodic sorting as their indexes get corrupted. I don't use any microripoffsoft stuff, only Open Office and iMac. Try reindexing your file with Open Office
Nov 01, 2015 | Microsoft Office 2003 Basic Edition...
Database corrupted
You can use Recovery Toolbox for Access is used for recovering data from corrupted Microsoft Access database files with *.mdb, *.accdb extensions.
For more: https://recoverytoolbox.com/repair_access.html
Oct 29, 2015 | Microsoft Office Computers & Internet
How do I easily repair corrupt or inaccessible Access database file?
Why to depend on anyone else suggestion. You may download one of the best access recovery tool which will repair your inaccessible access database file. This tool work on windows 10 & below versions also best thing is that free version of this tool will preview all your records after repairing your database. So you may preview your database and can easily review that your data is recovered and to export it you have to use full version. Try this access recovery tool. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
Sep 09, 2015 | Computers & Internet
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Storage of MS-Access 2007
(please refer for www.office.microsoft.com for further information)
Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
1 page header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
Project specifications The following list of tables is specific to Office Access 2007 projects:
General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
Zulfikar Ali
Jan 16, 2009 | Microsoft Computers & Internet
How to add columns(Vertical) only in Msflexgrid from database table using VB.
you have to open your current project in VB then go to "add references" (its somewhere in the menu bar) then go find microsoft acess and add it as a reference. then go to object browser and you'll find all the functions you need to interface between your project in VB and MS Access.
good luck !!!
Dec 30, 2008 | Computers & Internet
How to export table in ms access to excel
yes you can export your access data into excel, follow steps on how to export.
1. open your access database
2. open the table data you to export
3. under table data view click tools menu
4. select analyze
5. select ms excel
6. this will open your seleted access table in excel
hope this will help you..
Dec 13, 2008 | Microsoft Access 2002 for PC
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
Microsoft Office Access 2003 (077-02871) for PC Logo
129 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
