Dancing red pixels
Appears when monitor is conected with DVI . If I use VGA conection problem dissappears.
  • 1 more comment
  • frenchkey Aug 20, 2008
    The latest news: I tryed 22" Samsung monitor, even without it's drivers, and it works just fine. No more dancing red pixels.
  • p1agu3
    p1agu3 Sep 13, 2008
    I have a vp201b, which uses an LG/Philips LM201U04 as its panel.
    I am getting dancing pink and green pixels - they show up when different colors are being displayed. If the color is black, I see green dancing pixels / snow. If the color is light grey or white, I see pink ones.
    Nobody seems to know anything about this or how I could go about fixing it even if I was comfortable soldering connections on the panel itself.
    I replaced the backlight inverter this morning and found out that this is NOT the root of the problem with "dancing pixel" issues.
  • Anonymous Nov 03, 2008
    I have the same problem w/ 2 of these monitors. Good to hear is not the back-light inverter, although that would not have been my first guess. I've noticed with mine that you can "hit" it gently and it will go away until it is moved/"hit" again. which would lead me to belive its a bad soldier joint somewhere, just not sure where that would be.
Your Video Card´s DVI output is probably damaged. You will have to replace your video card , or use only the VGA output.
Posted on Aug 19, 2008
Red cable crt
Sometimes certain pins are missed or added more.
Or some pin connection are bad.
Try this.
Use VGA to DVI adapter from laptop and see what happes.
Jun 21, 2013 | HP L1910 19 inch LCD Monitor
Dear sir i have a apple cinema display m8149 lcd.i have loss my apple system(cpu) and want to run apple tft with other cpu (intel dvi and vga) tel me the how will conection or explane me where are RGB...
You can run that monitor from a DVI connection but you would need to get an adapter from DVI to ADC and that supplies power to the monitor. DrBott makes an adapter like this called the DVIator (http://www.dviator.com/) that should work for you if you other CPU has DVI out.
Mar 29, 2011 | Apple Studio 17" Flat Panel LCD Monitor
My PC has only VGA output and the LG monitor has DVI-D / VGA but the VGA connector seems to be damage. How can conect to the DVI-D conector in the monitor?
you can buy new vga connector, change the damaged with the new one, you can buy this part separately at computer shop at your town
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | LG Flatron L1919S LCD Monitor
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
No input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
May 02, 2009 | Computers & Internet
When dvi plug is used screen gets funny bright colored lines
FIX for design fault of ASUS VW222u Problems with monitor using dvi while vga works fine.
my ASUS VW222u had the same problem many are reporting after about 8 months
with developing colored "noise" onscreen or dancing red pixels while using dvi but vga is fine.
luckily my old man is an electronics engineer, rather than be without a monitor since vga still works fine we decided to have a look.
we worked out the problem. note: this is a fix for the random picture noise problem while using dvi port.
If monitor works ok with vga but dvi has noise then this fix should work for you.
1.open monitor (will void warrenty)
2.unplug all the the cables going to the power supply and dvi port assembly, undo two screws pull down and out you wil now be looking behind the dvi port and be holding a metal module that contails power supply and dvi- and vga port.
3.you will notice a piece of brass foil joining the earths on your dvi and vga cable this is the problem creating an "earth loop" as both vga and dvi ports are earthed to the metal casing this extra earth is causing the problem introducing noise.
3.carefully unwrap the brass foil from the two cables and seperate, insualte cables with electrical tape. (wrap around each one seperately they should now be indiivdual cables)
4.you will notice a silver spring type peice of metal on the assembly that pushes against the
main body of the unit when re-assembled. scratch the metal with a screwdriver where this peice pushes so you get a good connection when you reassemble it, do not touch as finger grease could screw up the connection. (this step is not vital just a good thing to do why your in there to make sure the the unit is properly earthed)
4.re-assemble
enjoy, fixed mine and was quite easy, take care with the plastic latches they are tight - ensure you remove all 5 screws, to see the fifth easily the monitor stand must be removed (two screws then stand slides out from rear of case)
good luck
bcmalloy
Apr 25, 2009 | ASUS VW222U Monitor
Monitor Problem
1. Try using a different media player like k-lite windows media player classic or GOM player.
2. Is the lcd set at it's native resolution ? Set it to native resolution.
3. Has the driver for the lcd been installed and does it show up properly in device manager ? Install the lcd driver if applicable.
4. What are your system's specs, especially graphic card ?
5. Has the latest graphic card drivers been installed ? Install latest drivers.
6. Does using VGA or DVI make any difference ?
7. You would've probably already checked windows media player settings.
Hopefully some of these will solve the problem.
Dec 22, 2008 | Samsung T190 19" Widescreen LCD Monitor
Computers & Internet Logo
428 people viewed this question
David Payne
David Payne
